ducatipaso.org • View topic - Paso 906 ECU
It is currently Thu Apr 30, 2026 5:25 pm
 Post subject: Paso 906 ECU
PostPosted: Sun Aug 14, 2005 10:57 am
I am still looking for a 1990 Paso 906 ECU. If anyone has any idea where to find a new, working used, or after-market alternative, I would greatly appreciate the information. The bike is a US model.
My wife is pushing me to "part out" the bike.
PostPosted: Sun Aug 14, 2005 7:56 pm
:cool:
Try http://www.mdinaitalia.co.uk/ and http://www.ducati-gowanloch.com/
PostPosted: Tue Aug 16, 2005 5:14 am
The 906 is not fuel injected and therefore does not have an ECU. Are you refering to the rectifier/regulator which fai regularly?
PostPosted: Thu Aug 18, 2005 11:56 am
Bone
In the ducati workshop manual, it is called Electronic control unit (ECU)
In the parts manual it is called the "Electronic device" part number 382400221A. Italian description " Centralina acc. MARELLI".
Have a look at previous postings on the subject. I had no confidence in my old one after a few repairs and just spent the money on one from Silent Hektik in Germany. I appears that it will probably last forever, whereas the original Marelli had problems from 17,000 km. I assume you are in America, so your exchange rate won't hurt like our Aussie dollar did!
Otherwise, get an electronics person to re-solder everything if price is an issue. Like I say check the previous posts.
You shuold update your profile of where you live in case someone nearby can help you. It would be great to have someone nearby to swap parts with when testing.
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
PostPosted: Sat Aug 20, 2005 4:03 pm
"Bone", CHANGE Your wife! :laugh:
I give advice: Try to find younger one!
Finnpaso
 Post subject: Re: Paso 906 ECU
PostPosted: Fri Jan 13, 2006 5:50 am
PostPosted: Fri Jan 13, 2006 8:14 pm
Rectifier is TOTALLY different thing, than Marelli (Ecu)!!! But i think, Marelli is not real ECU, what U have in 907, that P7 computer....Its ECU! :eek:
 Post subject: magnetti marelli ignition
PostPosted: Sat Oct 21, 2006 11:10 pm
I was having problem with my ignition unit .it would drop the rear cylinder at the most inconvienient of times[usually when passing]I evenually sent it to a tv repair dude who resoldered the curcuit board.Have had no problem for last 18 months.starts much better also .Ducati electrics suffer from bad conections especially solder joints which go porous[dry solder joint] but here is a hint DONT get drunk and rip unit apart in disgust apparently you do more damage than good???
PostPosted: Tue Oct 24, 2006 12:17 pm
PostPosted: Thu Dec 14, 2006 5:22 pm
PostPosted: Sun Dec 17, 2006 4:09 pm
PostPosted: Sun Dec 17, 2006 4:12 pm
PostPosted: Sun Dec 17, 2006 7:28 pm
PostPosted: Sun Dec 17, 2006 8:35 pm
PostPosted: Mon Feb 05, 2007 11:07 pm
Hi I have a spare merrelli ecu box if that is what you are looking for from a 91 906 paso. I am looking for the integrated indicator lenses. Thanks Mike
