ducatipaso.org • View topic - Headlight glass removal
It is currently Tue Sep 30, 2025 5:42 pm
 Post subject: Headlight glass removal
PostPosted: Tue May 21, 2013 9:13 pm
Hi Guys has anyone manged to succesfully sperate the headlight glass from the headlight casing - if so how - I'm guessing its bonded as well as clipped - whats it bonded with and how did you release it?
I'm trying to sit some LED daylight running lights in there so I have a bot more presence without the full beam on all the time given our "limp arsed" alternators!
 Post subject: Re: Headlight glass removal
PostPosted: Wed May 22, 2013 5:30 am
The adhesive that is generally used for a headlamp assembly is a urethane or mastic that is slightly foamed. Not meant to be taken apart. If you are dead set at taking it apart, besides with a hammer, you can fish a bit or steel braided wire between the two and saw the to parts apart like they do for a windshield. There is no solvent that will dissolve that bond without destroying the plastic bits around it. A dremel tool might be your best option. Or get two headlamps, and cut off the lens on one, and the reflector of the other, then glue them together. Or just buy the Yamaha one. Not a bit that takes well to changes.
PostPosted: Wed May 22, 2013 5:51 am
I've bought an LED strip that I will be fitting in the groove under the headlight. Should solve all probs. :thumbup:
Lane
89 Dark Blue 906 Paso
PostPosted: Wed May 22, 2013 7:39 am
why not try to find an LED bulb that fits in the parking light socket, who needs that anyway? Then just disconnect the wiring and you`re almost done. The socket should be a "Ba9s", just look for that and "LED" on the internet.
PostPosted: Wed May 22, 2013 9:12 am
PostPosted: Wed May 22, 2013 11:10 am
Maybe - I'd just like something a bit brighter than a single LED blub - have a neat little row of leds that I was planning to put on the little shelf bit in front of the reflector
I don't really want to mount anything to the fairing if I can avoid it and down by the calipers is too low
PostPosted: Wed May 22, 2013 6:42 pm
when you buy the Yamaha "Twin light" you have plenty room to add some LED lights between the reflectors. you only need to make some kind of supportive brace.
Bertus
Users browsing this forum: No registered users and 133 guests
