ducatipaso.org • View topic - Oil leaks heads-cyl, a solution?
It is currently Mon Sep 29, 2025 7:41 pm
 Post subject: Oil leaks heads-cyl, a solution?
PostPosted: Fri Apr 19, 2013 4:04 pm
Looks very interesting IMHO:
http://www.ducati.ms/forums/57-superspo ... k-fix.html
What do you guys think?
And there are two good Higgys out there... ;)
 Post subject: Re: Oil leaks heads-cyl, a solution?
PostPosted: Fri Apr 19, 2013 11:35 pm
Wow! My brother from another mother had a great idea........metal always works best and copper and brass can be annealed over and over again :thumbup: :thumbup: :thumbup:
PostPosted: Fri Apr 19, 2013 11:55 pm
I had always assumed the two people were one in the same, but I guess I was wrong in that assumption, especially since 3,000 miles separates them.
PostPosted: Sat Apr 20, 2013 2:59 am
ime
1/ the paso oil leak is from the heads 'warping', allowing oil to leak from the combustion chamber. no idea why they leak oil in stead of gas, but they do. i have the chamber and head face skimmed flat to fix them. altho a good dose of engine sealant may work. heap cheaper too.
2/ i think i could count the number of bikes (2v air cooled ducati) i've (or the shop i've worked at has) had apart for leaking oil return o-rings over the last 19 years on one hand. i'm very surprised at people having so much trouble with them.
PostPosted: Sat Apr 20, 2013 10:10 am
PostPosted: Sat Apr 20, 2013 3:04 pm
brad black...the famous, Brad the bike boy, the ducati guru, (what this guy doesn't know about ducatis is not worth knowing) welcome to our site :thumbup:
...btw, I do agree with everything you say :D
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Sun Apr 21, 2013 12:02 pm
PostPosted: Sun Apr 21, 2013 3:02 pm
heat them up on a hot plate/oven to 350-500F(176-260C) for 2 hours then torque them down on a flat 1 inch steel plate and let them cool down.
There are times when just heating/cooling the head (annealing) is all that is needed and there are times when the head needs to be torqued over a shim plate to get the desired flatness. You must not heat the head for more than 2 hours and lower heat is better as you can soften the material too much
Machining a head never solves a warped head issue it only flattens the sealing surface and by removing metal you increase the risk of future warpage.
I have seen a few old time techs weld new material to the head and then resurface it but here again the rest of the head is still warped. One individual straightened his flathead dirt tracker head on a press. Don't think I'd try either of these on a 2 valve duc head :banghead:
There are many websites and YouTube videos around showing the process these days
Oh and Welcome Brad, Nice to see you here :thumbup: :beer: :beer:
PostPosted: Sun Apr 21, 2013 4:29 pm
[quote]allowing oil to leak from the combustion chamber/quote]
The guy in my link had no oil leaks after his fix of the oil channels so where does the leak occur from?!?
I've measured head to cyl freeplay when cold, it is around 0,34mm, does this gap reduce to almost nil when engine is fully warmed,
anyone knows?
PostPosted: Mon Apr 22, 2013 6:30 am
PostPosted: Mon Apr 22, 2013 8:56 am
Cheers Claude.
PostPosted: Mon Apr 22, 2013 10:17 am
PostPosted: Mon Apr 22, 2013 10:19 am
PostPosted: Mon Apr 22, 2013 10:20 am
PostPosted: Mon Apr 22, 2013 12:42 pm
Cheers Claude.
Users browsing this forum: No registered users and 30 guests
