ducatipaso.org • View topic - Dyna coils on ebay (Austria)
It is currently Thu Oct 02, 2025 10:36 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Dyna coils on ebay (Austria)
PostPosted: Mon Nov 12, 2012 7:55 pm
Paso,
Yep, those V-tech coils is what I ment. They looked tempting to me. But at the end I bought Dyna's. the connectors have to be modified, because I want to back to original anytime. And I like those Amp. connectors.
also your edit about the single fire and dual fire is correct.
sounds maybe odd but is bloody simple. very often is that a ingredient for reliability. unfortunately there are some other issues with Harley.
Bertus
PostPosted: Tue Nov 13, 2012 12:52 am
Don't forget to open up your plug gap to take advantage of the higher energy coils :thumbup:
PostPosted: Tue Nov 13, 2012 9:44 am
is there a rule or recommendation about how much ?
PostPosted: Tue Nov 13, 2012 2:12 pm
From what I have come across last days studying Dyna coils and its fitting to a bike, gab on the sparkplug should be 0,9 mm.
It als stated that;
- Sparkplug wire diameter ouitside is 7 to 8mm
- Can be used an unshielded cable or shielded
- Suggest to use a lager inner copper wire, more strands, some race plugs have less inner copper wire,
- Can be used with original sparkplug wire and sparkplug cap from Ducati
- Can also be used with Dyna sparkplug wire and cap of NGK
- Suggest using an NGK sparkplug for full result
- Pay attention to the polarity of the coil
- And don't mix op standing and horizontal cylinder while fitting the coil and wire.
Looking at the installation it is a easy mod to be done. See
Note that the sparkplug wire connection is now at the underside of the coil, in line with the coil. Looks more easy than the exit at half the coil hight facing horizontal instead of vertical.
Proud owner of a;
- Ducati 907 ie 1992 in red
PostPosted: Mon Nov 19, 2012 3:19 pm
noone bid on the black Dynas I posted on the first page. They went for only $24.95!
PostPosted: Mon Nov 19, 2012 5:43 pm
Paso,
maybe the fact that they are black is the reason. no one would like a lime green Ducati. :evil:
Bertus
PostPosted: Tue Nov 20, 2012 9:05 am
I don`t get it
PostPosted: Tue Nov 20, 2012 10:51 am
another set
http://www.ebay.com/itm/Moto-Guzzi-T-3- ... 9e&vxp=mtr
PostPosted: Tue Nov 20, 2012 11:49 am
PostPosted: Tue Nov 20, 2012 12:19 pm
PostPosted: Tue Nov 20, 2012 6:26 pm
So not usable on the Ducati's as these need 3 Ohm versions.
Bertus
PostPosted: Tue Nov 20, 2012 8:39 pm
PostPosted: Tue Nov 20, 2012 8:50 pm
Proud owner of a;
PostPosted: Tue Nov 20, 2012 9:53 pm
PostPosted: Tue Nov 20, 2012 10:41 pm
So, I payed to much for mine. € 114 for a brand new set. :mad:
But, when she runs better as before, I get over that soon.
Bertus
