It is currently Sat Jun 20, 2026 8:12 pm
| Author |
Post subject: Re: Bike Stalls Once Warm and over 5500 RPM Posted: Fri Apr 27, 2012 2:51 pm |
| paso grand pooh-bah |
| Top |
bobst2
Post subject: Re: Bike Stalls Once Warm and over 5500 RPM Posted: Sat Jun 23, 2012 2:21 pm |
Joined: Sun Jul 24, 2011 1:57 pm Posts: 192 Location: delta b.c. canada
not to experienced with 907 but my 750 paso with u.s.igntion (single pick up coil)did similar things bought a 19 dollar pick up coil and magic problem gone. not saying its your problem but they can cause what is happening and sometimes only act up when warm. mine just died when hot then wait 15 mins and would start right up i chased the problem for a long time. there is a manufacturer part#( example marelli m9)on the actual sensor. ducati wanted $280 fiat car same part exactly $19
good luck
| Top |
cagiva905
Post subject: Re: Bike Stalls Once Warm and over 5500 RPM Posted: Tue Jul 31, 2012 9:22 pm |
Joined: Mon Apr 18, 2005 12:00 am Posts: 71 Location: Holland
Perhaps a bit late but your problem might be the cam position sensor or the speed sensor failing due to age. After a while they heat up by the engine, and due to age they start failing. If one of these sensors (they are in the alternator cover) fails, the engine will stop dead because it does not know running speed or timing, hence no injection. They are shimmed to a set distance from the signal knobs on the flywheel and intermediate cam wheel, with degrading performance they can become too weak to pick up the magnetic field.
A friend of mine worked on his Elefant 900ie last week (same injection system) after having swapped the engine (broken chain...), the engine had a self induced rev limiter due to the sensors being too far away from the knobs. Gave roughly the same symptoms.
Michiel
_________________ Michiel
http://www.endless-horizons.net http://www.endless-horizons.net/efi/efi.htm http://www.elefant.nl
| Top |
bobst2
Post subject: Re: Bike Stalls Once Warm and over 5500 RPM Posted: Thu Aug 02, 2012 11:35 pm |
when you restart it will it only rev to a certen rpm then cough & sputter if yes how long does it take /cool down before it acts normal
| Top |
bobst2
Post subject: Re: Bike Stalls Once Warm and over 5500 RPM Posted: Thu Aug 02, 2012 11:40 pm |
+ 1 on possible pick up coils issue thats what i was getting at. just went through it on my 750 paso with digiplex ign. check out 3200 rpm & stall thread on 750 section was very anoying and had to chase it for a long time to figure it out.good luck
| Top |
Users browsing this forum: No registered users and 6 guests |
