ducatipaso.org • View topic - Norway callling! New member.
It is currently Thu Mar 12, 2026 9:23 pm
 Post subject: Norway callling! New member.
PostPosted: Sun Mar 25, 2012 7:59 pm
Here are some pictures of my bike, 1990 Sport.
best regards Rune
 Post subject: Re: Norway callling! New member.
PostPosted: Mon Mar 26, 2012 4:37 pm
Absolutely gorgeous! perhaps my favorite Ducati model of all time. Thanks for showing us the pictures. Change out that rear tire or be careful. :)
PostPosted: Mon Mar 26, 2012 7:13 pm
Very Nice bike. Especially like the 2 in 1. Who made it?
Greets Joep
PostPosted: Mon Mar 26, 2012 7:43 pm
PostPosted: Mon Mar 26, 2012 8:00 pm
PostPosted: Mon Mar 26, 2012 9:06 pm
model: other
Welcome, and love the 2 into 1's look great, floating front disc conversion, from who? my 280mm brembo's are warped :,( and need to replace.
Peter
PostPosted: Tue Mar 27, 2012 2:37 am
Nice job on the rear cowl mod. Is that stock parts fused together, or did someone do a fiberglass redo?
I see the stock pillion pegs/muffler hangers have been removed.
Exhaust looks like the GiaCoMoto that I have bits of, but yours is complete.
Welcome to the site.
Did you do most of the work, or was it the previous owner/s? Whats on your list for next steps?
PostPosted: Tue Mar 27, 2012 9:00 pm
PostPosted: Tue Mar 27, 2012 9:33 pm
PostPosted: Tue Mar 27, 2012 9:44 pm
Hi.
Here are some more pictures with the correct color on the bike and its surroundings. :)
Its not me in the saddle.
Best regards Rune.
PostPosted: Wed Mar 28, 2012 2:44 am
Those carbs are a bit big for that engine, but if you get them to run OK, then I guess they're OK. 36mm is the recommended size.
I recommend putting big rubber elbows on those carbs and put some big sock filters on top of those up above the carbs. Gets the intakes into cooler air, gives you bigger air cleaners, and smooths the flow of air coming into the carb.
When you get your new pipes, you can easily sell that set up here on the list. It is one of the few 2 into 1 pipes, and produces good power, but it is loud.
PostPosted: Thu Mar 29, 2012 8:05 pm
PostPosted: Fri Mar 30, 2012 7:23 pm
Have just purchased this.
http://www.pieces-detachees-occasion-du ... port-.html
:D
Best regard Ru
PostPosted: Sat Mar 31, 2012 7:27 pm
PostPosted: Sat Mar 31, 2012 7:29 pm
