ducatipaso.org • View topic - Left engine cover removal
It is currently Thu Mar 12, 2026 9:32 pm
Post new topic Reply to topic  [ 94 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: Left engine cover removal
PostPosted: Wed Dec 28, 2011 12:05 pm
Thanks for the picture tutorial i understand what i must now do, this has made the job a lot easier . That will be my job in the morning. :thumbup:
PostPosted: Wed Dec 28, 2011 9:56 pm
the b&w pic is from the Monster/SS Haynes manual. You find it in the downloads topic in the P750 forum. I replaced the old files with a better version today.
PostPosted: Thu Dec 29, 2011 1:35 am
Ok i have determined to rotation for the Sprag and as a precaution i have shortened the old Starter Sprag Spring by a 1/4 inch and kept it as a spare. My next question is this, on fitting the new SKF Sprag the lock ring that held the old sprag in will not fit back into its recess the new sprag is about 0.5mm higher than the old. does the lock ring go back in with the new Sprag?
PostPosted: Thu Dec 29, 2011 10:02 am
I don`t know as I have the SKF sprag only as a spare. In case noone knows you could try to contact bevelheaven.
PostPosted: Thu Dec 29, 2011 3:45 pm
you could also try to call bevelrubber in AUS as they are selling them, too.
http://bevelrubber.com.au/cart/index.ph ... ucts_id=79
The lock ring is needed as not only does it hold the part in place but as I heard it should also prevent the assy from running dry by stopping the oil that`s pressed out by the centrifugal forces.
PostPosted: Fri Dec 30, 2011 11:54 pm
Well after all i said and done the Old sprag has gone back in with the spring shortened because i didnt like the fact that the new one was to thick to put the retaining circlip back on, so everything is ready to be buttoned up ,ordered my new Gasket from Gowanlach and it arrives after 10 days and ....... aaarrgghhh they have sent the wrong bloody Gasket , with it being New Years here i cannot make contact with them to tell them of the mistake i have tried everywhere for another Gasket but no luck so the Paso is sitting in the Shed with the cover still off and is going no where unless i strike out and get a tube of Locktite Super Grey which i am at a half a mind to do. But i did read here somewhere that the Gasket was important for its thickness mmmm ive had a look and some how that argument does not convince me. I really do need to get her going its been 8 months since she and i have had a run. :banghead:
PostPosted: Sat Dec 31, 2011 4:46 am
Well the bike is all back together , insert the Key and hit the starter......... excatly the same no change, starter motor is spinning freely and not engaging damn it all i wish i hadnt touched the old girl now with the Hicap starter upgrade i had no problems up till then, im not blaming the Hicap but yeh that was the last time she fired up :,(
PostPosted: Sat Dec 31, 2011 10:00 am
what you could have done is place a wet sand paper on a glass panel and sand off the 0,5mm so the SKF part would`ve fitted. Being the wider side I`d done that on the edge with the cut out.
Then blow it off with the compressor and wash it to get rid of any metal dust.
Assuming the old starter sprag is now mounted exactly like before and not reversed there`re several causes possilbe.
1. old starter sprag too worn
2. surfaces of clutch gear or flywheel worn
3. are the cables of the HiCap kit connected correctly ?
4. had you removed or opened the starter to ie change the brushes ?
Just wondering if the starter motor is running reverse. If I`m correct you should see it spin clockwise when the left engine cover is removed (edit: correct is counterclockwise!). If you try that disconnect the spark plug cables !
PostPosted: Sun Jan 01, 2012 12:27 am
Yes Paso750 with the Left hand cover off the Motor the Starter does spin Clockwise so this acording to what you have written and the way i am reading it is the wrong way for it to spin? and this would make sense as the Ring Gear will lock when spun counter clockwise if so this would go way back to when i replaced the brushes and there is some discussion here on the forum about the Starter spinning backwards the general opinion then was that this could not happen but i did get a replacment set of Brushes and installed them and if memeory serves me correctly they would only fit one way, this is not to say that they had been put together incorrectly at the point of manufacture so i am going to remove the end cap from the starter and have another look . My new years resolution is to have the Paso running by tomorrow lol it even put a damper on my new years celebration last night as it was all i could think of haha, mmmm looks like the Paso has enerted my blood and will not let me rest. :D
PostPosted: Sun Jan 01, 2012 1:08 am
Ok with the Starter Motor pulled apart and the Brushes removed it is phsyicaly impossible to put the Brushes in any other way. It is correct for the battery + to go to the Starter Motor yes? after going through the Solenoid.
PostPosted: Sun Jan 01, 2012 2:20 am
One other thing that i has just came to mind is when fitting the Hi Cap upgrade it was suggested to me on here that instead of running the Earth Wire to the Frame where it was originally, run it to the Engine, now i may just be grasping at Straws here but do any of you think that this could be the cause of the Sarter spinning backwards? its a long shot but hey i am coming to the end of the road with this so to speak and running out of ideas as to what is happening.
PostPosted: Sun Jan 01, 2012 10:22 am
PostPosted: Sun Jan 01, 2012 1:29 pm
I have a spare gear with the stock sprag,I'll see which way it rotates
PostPosted: Sun Jan 01, 2012 2:34 pm
Thanks Higgy it will be ineteresting to see what you come up with.
PostPosted: Sun Jan 01, 2012 2:47 pm
To be sure, I always run the starter f 2 secs, w/o plugs,
f checking sprag engages before mounting eng cover.
