ducatipaso.org • View topic - Dunlop D250 180/60R 16 fitted
It is currently Mon Sep 29, 2025 3:36 am
Post new topic Reply to topic  [ 186 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13  Next
 Post subject: Re: Dunlop D250 180/60R 16 fitted
PostPosted: Thu Dec 23, 2010 10:40 am
Higgy, you and rhino should swap nicknames.
I don`t get what this is about anymore. I`m no engineer but appearently one has to be one to ignore what other engineers (ie from a tire manufacturer) state. Interesting point - don`t get it.
As one of the moderators of this prospective suppressed and communist Paso enthusiast community I`d suggest we draw the line where it starts to get personal and get back to the topic.
All helpful information, comments or questions are more than welcome. Who just wants to show off their superior attitude should post that part on Facebook or the NRA forum.
Happy Kwanzaa
PostPosted: Thu Dec 23, 2010 11:36 am
PostPosted: Thu Dec 23, 2010 11:38 am
PostPosted: Thu Dec 23, 2010 10:22 pm
I don't want to get my head bit of being a noobie and all that, but you CAN shave a bit of the tyre edge without compromising the safety. OK there is a limit as to how far but upto 5 mill is fine.
I used to race in the old TZ 250 and lc 350 proddie races both on track and road, when modern (and stickier) tyres came out everyone in the paddock put these overwide tyres on and had to shave off the shoulders to make them fit. The tyres had a harder life than any road bike would give them and not one ever failed.
Only my opinion and if your not sure then just don't do it. :)
PostPosted: Thu Dec 23, 2010 11:11 pm
[quote="907pasonut Baaaa Baaaa!!![/quote]
Oy ! Leave me out of this :lol: :lol: :lol:
PostPosted: Fri Dec 24, 2010 12:45 am
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Fri Dec 24, 2010 8:57 am
ukizook, noone`s gonna rip your head off :) As 5mm sounds like a lot to me which tires were these and how did you/they do it ?
PostPosted: Fri Dec 24, 2010 12:43 pm
G, All the tyres you buy today usually have about 6mill tread depth when new, the rubber extends beyond the thinner sidewalls. We just had a pad on an angle grinder and was very gentle with the pressure (or the clever ones borrowed someones tread cutters and hot knife
I doubt any Paso rider would ride to the edges of a 180/60 profile tyre "not through any lack of ability of rider or bike" ;) but I see many 180 tyres with over 5 mill wear on the very edge of them after a vigorous trackday. I know it's not quite as simple as this but imagine you had a brand new tyre and managed to (evenly )wear 5 mill of the entire tread. Apart from now having a nearly bald tyre everything else would still be fine.
Again this may not be the optimum fix and I for one chose C Boys fix with an old turned down sprocket as a spacer.
The only drawback of a 180 tyre that I see is the limited chain adjustment. :thumbup:
PostPosted: Thu Jan 06, 2011 5:33 am
PostPosted: Thu Jan 06, 2011 8:56 am
Welcome Michael,
I am 100% on your line.
I also ride more than 75% on the center line :mrgreen: :mrgreen: :mrgreen: :mrgreen: and I also do think we need to undertake us to avoid any misunderstanding among the people.
About the topic, when I used to have a wonderful blue 906, my mechanic always suggested the 150/80 rear tire.
I think the 180 tire is too wide, needs too much mods to be fitted and, finally, does'nt look so good on the Paso. Just my 2c opinion ;) ;) ;) ;) ;) ;) ;) .
I hope to read you here again :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: .
Ciao :beer: :beer: :beer: :beer: :beer: :beer: :beer:
PostPosted: Thu Jan 06, 2011 11:58 am
PostPosted: Thu Jan 06, 2011 12:12 pm
welcome Michael...we would love to see a pic of your bike, although the people around you are telling you to sell the bike...I think...respect it, but...dont sell it, so good choice there! :thumbup:
good luck with your back op recovery :beer:
Cheers Claude.
PostPosted: Thu Jan 06, 2011 12:33 pm
@Mycle
in addition i still like to mention the step I have taken regarding the Paso tire problem. I am
indeed very happy with this solution. It is a quick fix and it is a matching modern zr-rated pair:
viewtopic.php?f=2&t=4463
Maybe this is helpful for your decision.
All the best, hardo
P.S.: My Paso 906 also has this strange blue colour => is it same as yours?
PostPosted: Mon Jan 24, 2011 5:53 am
I have been watching the topic and those advocating either grinding/cutting the side off the tyre, or fitting a 150-80-16 instead.
I am obviously opposed to modying the tyre from a purist's point of view. It just seems a bodge and would annoy me every time I looked at it. Also there is no need to resort to it.
I offset the front sprocket by 10mm as it was easy to just turn it over and I had no real data as a starting point. It did create some complications with rear sprocket cap-screw head clearance to the swing-arm. When all assembled I found I had 8mm chain/tyre clearance (I believe the original was 10mm). This could be cut back to 3mm by not turning the front sprocket over and machining 5mm off the outside. Rear sprocket would still need a (narrower) spacer in the way I did it but there would be no cap screw issues. All other spacers for chain guard etc. would be reduced by 5mm ofcourse. Kick stand clearance would be easier to achieve.
I make the above suggestions to illustrate that the info I supplied can be used to offset your chain however much you choose - to a maximum of 10mm.
As to the 150-80, I have asked on that thread how the bike handles two-up.
And lastly to my friends in Tuscany, my travel plans this time prevent me accepting the offer of a ride :( - and race around the Piazza at Sienna. ;)
However, we will be visiting Bologna and on to Venice so I will have some pictures of boats to post here. :lol: :lol: :lol: :lol: :lol:
Cheers, CB :thumbup:
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Sun Jan 30, 2011 9:33 am
Unfortunately, I have been moved from Tuscany and by now I'm on the northern Lazio, 100 kms. away from Roma.
However, I'd be very happy to come back to Tuscany and, above all, to Siena because it's a long time I don't see her.
Ciao :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
