ducatipaso.org • View topic - Dunlop D250 180/60R 16 fitted
It is currently Mon Sep 29, 2025 8:22 pm
Post new topic Reply to topic  [ 186 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13  Next
 Post subject: Re: My D250 was touching the chain sometimes
PostPosted: Sun Dec 19, 2010 6:12 am
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
 Post subject: Re: Dunlop D250 180/60R 16 fitted
PostPosted: Sun Dec 19, 2010 8:16 pm
Removing excess rubber without touching the inner fabric has no effect on a tires integrity.
The area at question is significantly thick with unsupported rubber which serves no purpose other than cosmetic...
If you get someone representing a tire manufacturer to speak to you he's not going to tell you it's OK to modify a tire in any way due to his concerns about his legal liabilities.
Again, I will state I'd hate to live in a country where the government stifled customization and free thinking to the extent I've heard about here... :P
The idea that some government bureaucrat can stifle hot rodding to this extent is appalling. :zip:
PostPosted: Sun Dec 19, 2010 8:39 pm
PostPosted: Mon Dec 20, 2010 5:11 am
Sorry paso grand pooh-bah but you are the one misleading people here.
Not all of us are sheep.
Some of us prefer to think for ourselves...
No one said anything about cutting on the sidewall where it is thin.
You obviously know nothing about American hot rod ingenuity.
It comes from living in a true Democracy and using your own brain rather than "follow the leaders" like mindless sheep.
I own a thriving business that relies on creative thinking and application of new ideas and I've been doing it a very long time. I am a licensed mechanicl engineer. I worked for the Department of Defense and the Department of Energy at Lawrence Livermore National Laboratory for 20+ years before going into business myself. I think for myself "outside the box" when necessary. If all people were afraid to try new ideas we would still live in caves.
I can just imagine how much bull crap you would have to endure to create and operate a machine such as my boat here:
Shown above at 105 MPH.
PostPosted: Mon Dec 20, 2010 10:14 am
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
PostPosted: Tue Dec 21, 2010 8:09 am
Well I'm pleased to see some support for my concerns about removing rubber from the sidewall. I suspect that rubber is there for more than cosmetic reasons.
I went to a lot of trouble to document a way to fit a 180-60 without resorting to the kind of butchery displayed here. My tyre is off the shelf and clears everything (and so does the chain). Mobius' one has been attacked with a belt sander - and looks like it.
When it comes to cars and bikes I too am a "free thinker", but I won't bore you with pictures of my creations. What the hell are pictures of a boat doing on this thread?
CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Tue Dec 21, 2010 11:38 am
PostPosted: Wed Dec 22, 2010 11:31 am
Man, where is this topic going ? It almost reads like for some doing whatever they want is a matter of patriotism and pride.
That is one nice engine on that boat, I must say. Still I also don`t get why that belongs here. It only shows that there`re also other unsafe things one can do. In summer I see a lot of guys in shorts and Tshirt on big bikes and for some unknown reason they seem to have all the luck. While they usually walk away with a few scratches others in full gear are less lucky if something happens…
Regarding tires I`d be careful about putting it all in general.
The sidewall design is there for a reason. It will give you more contact surface if you lean compared to a tire that has a round profile or steep flanks like a car tire.
As there`s no carcass to support this overhang as below the cover of the tire the rubber is very thick there.
The width of tires varies depending on manufacturer. So it`s not that uncommon that a tire touches the chain slightly and gets grinded down by it.
I personally think it`s possible to remove 2 or 3mm of that edge (on the Avon) although that`s definetely not something I would do.
I would never recommend anyone to go for it with an angle grinder or knife. You never know who reads this and how knowledgeable and skilled someone is. A former colleague from Argentina would say that is like giving a monkey a knife.
So if, use a grinding block with sandpaper, nothing that cuts, do it by hand, do it evenly and carefully and only if you know all the possible consequences.
Also be very aware about which tires we´re talking about ! We´re talking about a 180/60 which is a strong tire with lots of rubber on it. Don´t think about doing this on any other and beware that even a 180 can have a different design depending on model or brand!
The Avon I have is wide and without spacers the chain would not only touch the tire slightly but it would put some pressure on it so I doubt that lowering the side edge minimally would really help. You´ll need to move the chain anyway.
To anyone who reads this. Don´t just blindly follow anything you find on the internet without giving it some proper thoughts yourself.
The argument that narrow tires improve handling is the same general statement which is bs.
It is correct, don`t get me wrong. Of course a bicycle handles better than a Paso but that is not what it`s about. I guess all manufacturers and race teams would be wrong then. They should put a 160 on a 6” rim which normally carries a 180 or 190 tire…
Narrow tires on a Paso will only improve the handling if you`d also change to narrower rims. Just pulling narrow tires on wide rims won`t do the trick.
That wider tires don`t handle well is bs as well. It totally depends on the bike, rim size (hence profile of the tire), suspension etc. I`ll bet my bike that a tire on a recommended rim handles better than a stretched one that is made for a rim three numbers smaller.
Merry Christmas to all.
PostPosted: Wed Dec 22, 2010 6:35 pm
PostPosted: Wed Dec 22, 2010 8:53 pm
I'm an engineer with over 40 years experience building custom motorcycles, cars, boats, you name it. If it's fast, most likely I've experimented with it.
I have run over 200 MPH more times than most of you have gone 120. The fastest I've gone was 237 mph at El Mirage dry lakes in southern Cal.
I am still in great health at 62 years old.
I have a very successful motorcycle accessories parts and customizing business.
I ride most every day and have ridden over 1 million miles.
I make a living doing what I love.
How many of you can say the same?
I am an engineer.
I didn't get where I am by being a pussy waiting for someone to Analise and approve my decisions for me.
If you have no faith in your own judgment and require your government or some other "authority" to make decisions for you, I pity you. I guess that's partially why Communism is the wide spread disease it is.
America has risen to be the major power it is because of innovative, creative people not being afraid to try new ideas.
Some of us are men, others are sheep.
PostPosted: Wed Dec 22, 2010 10:42 pm
those last few lines are the worst republican bullshit I ever read on this forum! How ignorant is that?
PostPosted: Thu Dec 23, 2010 1:51 am
PostPosted: Thu Dec 23, 2010 2:46 am
PostPosted: Thu Dec 23, 2010 2:48 am
....Im here doing some bookwork, and must say this post is interesting...:thumbup: :thumbup:
MERRY CHRISTMAS AND A HAPPY PASO NEW YEAR EVERYONE!
Baaaa Baaaa!!!
Cheers Claude.
PostPosted: Thu Dec 23, 2010 4:30 am
