It is currently Fri Jun 19, 2026 11:50 pm
 Post subject: Bike reving by itself
PostPosted: Mon Jun 21, 2010 7:45 pm
can anyone suggest a reasio why the revs rise on there own to between 2-3000 rpm in netural when stopping
 Post subject: Re: Bike reving by itself
PostPosted: Mon Jun 21, 2010 8:19 pm
1. You have pissed of the Ducati Gods
2 Your cables are binding
3 You have a large air leak you need to fix,ASAP!
4 Your float needle is sticking
5 You have pissed off the Ducati Gods
6 None of the above as you have provided too little information
pissing me off :thumbup: :thumbup: :lol: :lol: :lol: :shock: :shock:
PostPosted: Mon Jun 21, 2010 8:39 pm
3) 4) Or a too lean mixture and a too high idle
PostPosted: Mon Jun 21, 2010 9:06 pm
Mate,
Could be a number of things. But I would start by doing the easy (and cheap) things first and seeing if they help.....
From the above:
Cable/throttle binding - dissassemble the throttle assembly at the RHS grip, clean everything. Slack and remove throttle cables, inspect (replace if sheathing broken or looks rusty). If OK, lubricate and replace.
If that doesn't work maybe you really have pissed of the Ducati gods and carb drama awaits.....
No dirt is getting into the carbs by any chance (no filter, no airbox, loose lid,?)
Mick
906 Paso 1989 w/ 17in wheels :)
PostPosted: Tue Jun 22, 2010 7:11 pm
Thank you for the advise how to start searching at the weekend
