ducatipaso.org • View topic - Dunlop D250 180/60R 16 fitted
It is currently Tue Sep 30, 2025 10:35 pm
Post new topic Reply to topic  [ 186 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 13  Next
 Post subject: Re: Dunlop D250 180/60R 16 fitted
PostPosted: Fri Apr 09, 2010 10:27 pm
PostPosted: Fri Apr 09, 2010 11:24 pm
PostPosted: Tue Apr 13, 2010 10:49 pm
Apologies for the confusion; my Metzler M3 Sportec is indeed 130/70/16, and *not* 60 profile as I wrongly stated. The rear is the D250 180/60/16 same as CBs.
Having now worn the brake pads and new discs in, I have been experimenting with various braking maneuvers and can report that I have managed to lock the rear wheel a few times either with heavy rear wheel braking or downshifting and missing a cog (4th to 2nd).
When using *just* the rear brake I have been very impressed with how hard I can brake, and have not been able to lock it up. Combined with heavy front braking though, I have grabbed the rear a few times when decelerating *hard*. It hasn't done anything "weird" at all. The tyre doesn't seem to give much warning that it will lock up (But probably my senses need more fine tuning in this regard) but it doesn't step-out or behave badly when it does lock. And it doesn't seem to have any problem at all finding grip again when I let some brakes off.
The front tyre seems very good indeed, although as an old-fart who is well aware of how much it hurts to hit the planet going quickly I have not pushed the front end terribly hard. Peter - one of the other board members here rode it and reckons it is understeering at low speeds - but I cannot detect this in my own riding.
CB, I'll rip the fairing off and photograph the front and rear sprocket locations and setups for you when I get home tonight, so you can compare them. The chain has now stopped removing rubber from the edge of the tyre, as I have cleaned the rims, and there is no new rubber accumulating on them.
PostPosted: Wed Apr 14, 2010 7:34 am
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Wed Apr 14, 2010 9:52 am
Here we go:
The back tyre is about 2cm off the ground on the centre stand. Ex-center is at about 5 o'clock on the chain side.
The front sprocket location.
Looking through the frame at the chain guide.
The rear sprocket and it's location.
PostPosted: Wed Apr 14, 2010 7:00 pm
Thanks for the photos. We now know your front sprocket is fitted correctly for standard - with the offset in. Please tell us where Duane showed you the chain would wear a hole if you offset it out 10mm.
Cheers, CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Wed Apr 14, 2010 9:08 pm
Hi CB. My own rather amateur inspection actually contradicts what he told me, and it *does* look like it could be shifted over by around 10mm without touching the frame. It's the first time I have seen that area of the bike with the fairings and cover off, so I am a bit mystified as to why he would say that shifting it over by 10mm would "eat the frame". No explanation sorry! It seems I should have inspected it myself before passing along his opinion, as it has caused you to spend some time mucking around that you shouldn't have had to - so for that I apologise!
Now to fix my gear-shifting issues...
PostPosted: Thu Apr 15, 2010 6:29 am
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Sun Apr 25, 2010 7:07 am
Today we rode the 906 two-up for the first time. In fact I hadn't been on a bike for a couple of weeks because I fell over and popped a couple of ribs out. No, I wasn't drunk! We rode with friends to a country pub about 60kms away. A good country road with plenty of fast bends and a few slow tight ones too. We had 35psi front & rear and the Paso handled beautifully. Very sure footed and giving me plenty of confidence to lean it over and crank it on through sweeping turns.
Here's a photo of me outside the pub. Multiple bike ownership prevents the purchase of a razor :lol:
Francesco, Jenny asked me to take this photo for you :shock:
What is it about Italian men? :mad:
Cheers, CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Sun Apr 25, 2010 7:57 am
PostPosted: Sun Apr 25, 2010 8:26 am
Frankie, You DIDNT told us what ALL You had in Your mind!!!(I know You...) :mrgreen: Pretty combination, Jenny and nice 906 Paso :thumbup: :thumbup: :thumbup:
PostPosted: Sun Apr 25, 2010 1:02 pm
Frankie, you're married!
Ladies are not expressly designed to be appriciated by married men!
(By the way, I'm single...) :lol: :lol: :lol:
PostPosted: Sun Apr 25, 2010 1:56 pm
Frankie is married with wife and 2 x 907IE's and seems, that Jenny is maried with CB, so also You, Nicola can forget all what You guys have in Your mind! :mrgreen: :mrgreen: :mrgreen:
PostPosted: Sun Apr 25, 2010 5:19 pm
My only love has two wheels and a yellow painting...
PostPosted: Sun Apr 25, 2010 7:02 pm
U say so NOW, but one day come pretty blond to Your eyes and then "all is over" ....with Your Yellow Paso! ... :mrgreen:
