ducatipaso.org • View topic - Dunlop D250 180/60R 16 fitted
It is currently Thu Oct 02, 2025 8:10 am
Post new topic Reply to topic  [ 186 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 13  Next
 Post subject: Re: Dunlop D250 180/60R 16 fitted
PostPosted: Tue Mar 09, 2010 5:14 am
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Wed Mar 10, 2010 5:15 am
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Fri Mar 12, 2010 10:07 am
New battery collected today and fitted. Bike now cranks really fast but doesn't fire. Last time it was inactive for a while I rolled it down our driveway and bump started it, so I will try that again. However that will have to wait until Sunday afternoon as we are off to Wellington (about 200 miles away) this weekend on the Triumph (sorry v2barn!).
Cheers, CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Fri Mar 12, 2010 11:55 am
Hello CB and fellow 906ers, Called Dunlop UK still waiting for a reply but i have deduced that tyres are diametrically the same from info on net.
As for leaving the UK 45 years ago i would say congratulations!! best move you ever made, i wish England was the same as you left it, this place has been sold down the river by every mealy mouthed politician since you left.
I have recently returned from living in France for 2 years and i have to say i wished i had stayed.
This country is nothing like you remember my friend, keep those rose tinted specs on as to return now would be a shock to say the least; the 'empire' is long gone and to coin an old phrase from those days 'the natives are revolting'!!!!!!!!!!!!
No apologies required CB all in your own time, hope you had a good trip to Wellington on the Triumph (what type?) somehow wish i was following you there on my Norton.
All the best with the 'project'
Cheers :beer: Jon
PostPosted: Sun Mar 14, 2010 5:55 am
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
 Post subject: Start-up after lay up
PostPosted: Sun Mar 14, 2010 4:55 pm
There are a couple of tasks to do when a Paso is laid up. Remove all fuel from the pipe lines, fuel pump and carburettor, or the fuel will evaporate and cause the float valve to stick in the 'down' position. disconnect the fuel return pipe from the petrol tank*, the fuel slowly evaporates from the fuel tank and exits through the carburettor, causing (you guessed it) the float valve to stick in the 'down' position! Remove the battery, keep in a warm place (to prevent freezing) and recharge every 2 weeks.
I have introduced a small pipe to the airbox so I can squirt some Easy-start into the bell mouths to aid starting. The 906 has not been run since mid November and it looks like I will have the joys of getting it to run in a week or two.
* Temporarily block the tanks return pipe tube to prevent petrol gassing off.
PostPosted: Mon Mar 15, 2010 4:36 am
Thanks JW - will take your advice.
Cheers, CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Thu Mar 18, 2010 8:26 am
If anyone watching this topic can offer advice on the fuel system I would be grateful if you would view the topic "Fuel Return Line". Bike is frustratingly close to running!
Cheers, CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Sat Mar 20, 2010 3:15 am
Ok so now it is running again I took it for a quick squirt up the road. I have only refitted the front guard, tank, seat & tail cone so it looks a bit odd but I live in a quiet blind rural road where most of the residents are petrol heads :thumbup:
First thing I heard as I went down the drive (no helmet) was the chain hitting the centre stand occasionally. I will address this properly when I lengthen the legs.
My smile broadened as I went up through that sweet little gearbox but I was surprised at the effort needed to make it turn into the first bend in the road. I think that this must be a Paso thing rather than a tyre thing as I have been riding my Triumph Sprint which turns in very easily - quicker than my GPZ for example. I welcome any comments comparing the Paso's handling to that of a more modern sports bike or ST please.
I know you are all wondering about rear tyre grip under braking so I braked hard with both brakes applied normally with no rear lock-up. I would add that the road was dry. It was only after I braked hard a number of times using less front and more rear that I eventually got the rear to skid. By then I was only touching the front and abusing the rear to do it.
I am next going to fit the fairings and prepare it for its Warrant of Fitness. I will take it for a much longer shake-down run when it is looking more 'legal'.
I have decided to lengthen both stands but haven't decided whether to return the excenter to the original position or not. My feeling is that I should. Comments welcome.
Cheers, CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Sat Mar 20, 2010 3:52 am
PostPosted: Sat Mar 20, 2010 5:24 am
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Sat Mar 20, 2010 11:34 pm
CB do you see any prob's with the warrant of fitness regarding the fitment of the new size tyres? would you even mention it? when i do the same conversion on mine i can't see any reason why i would need to mention such a conversion to the MOT test guys, any body else got a view on this 'declaration' ? i assume from what i have read the German authorities want an approval from the manufacturer before such a 'modified' machine was subject to a test.
I am convinced it is not a 'tyre size thing' it's more of a 'familiarity thing' ie. once you have put a few miles on the new rubber and got used to the bike, the handling will be fine for the sort of riding most of us do.
Ignore the detractors (that's just a tosser thing) carry on the good work and keep us informed of progress. Cheers :beer: jon
PostPosted: Sun Mar 21, 2010 2:10 am
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
PostPosted: Sun Mar 21, 2010 5:36 pm
"My smile broadened as I went up through that sweet little gearbox but I was surprised at the effort needed to make it turn into the first bend in the road. I think that this must be a Paso thing rather than a tyre thing as I have been riding my Triumph Sprint which turns in very easily - quicker than my GPZ for example. I welcome any comments comparing the Paso's handling to that of a more modern sports bike or ST please."
hi DB
I really think that is the typically paso behavoiur caused by the smal 16'' wheels. because the wheels are quite wide anyway (130 and 160 or 180), the driving is much different to - e.g. a moto guzzi (I have one) with 17'' or 18" wheels -. this "strange feeling" will be less whenever you drive faster through the corner. In this forum, you can read old road test and they decribe this effects too.
all the best - we are looking forward to here mor from you
PostPosted: Sun Mar 21, 2010 6:04 pm
Thanks hardo :thumbup:
Progress on refitting the fairings came to a halt when I discovered a crack in the lower right-hand radiator bracket. Will take it to work to weld up. Suggest you all check that bracket next time you have the fairing off.
Cheers, CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
