ducatipaso.org • View topic - Starter Relay
It is currently Mon Jun 22, 2026 8:41 am
 Post subject: Starter Relay
PostPosted: Tue Jan 26, 2010 12:12 am
My starter relay is a "Hitachi - 12v - MS5A- 181 or M55A". This must be an after market replacement, right? If it is, is this the preferred model or is there a better relay?
Thanks.
 Post subject: Re: Starter Relay
PostPosted: Tue Jan 26, 2010 4:41 am
907 use Hitachi relay, but i cant remember now number.... Same as in newer modells.
PostPosted: Wed Jan 27, 2010 1:33 pm
It isn't a replacement.
On both 907s I have Hitachi relays and they work very well, unless the connections were rusted.
Check for rusty connections.
PostPosted: Fri Feb 19, 2010 5:33 am
Amazing what the cleaning of all connecting terminals/cables for starting the bike and a new battery will do for instant firing of the bike! Before had a delay of about 1-2 seconds and weak starting sound when fired. Now, starts just like a car!
PostPosted: Fri Feb 19, 2010 9:24 am
But LUCKILY it is NOT "a car" :mrgreen: Its very important to keep all connections and cables in good condition and well lubricated against rust with right lubricants. That can solve alot of all elerctrical gremlings in Ducati.. especially in charge system!... :thumbup:
PostPosted: Sun Feb 21, 2010 3:50 am
Suggest you make a small hole in the bottom of the rubber boot over the starter motor "+ve" cable.
This lets the water out before it rusts the nut to the bolt.
Mine was fully rusted and a major pain to fix.
Auto electrician also said to paint over the whole nut/bolt to keep out the water as its the main reason for failure
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
PostPosted: Sun Feb 21, 2010 1:16 pm
PostPosted: Mon Feb 22, 2010 11:28 am
according to ca cycle works web site , the yamaha starter relay works, USD$42
http://www.ca-cycleworks.com/shop/catal ... /elec.html
go down the page to battery and charging
Nigel
Lambretta LI150 S3
87 928S4
PostPosted: Tue Feb 23, 2010 4:23 am
I did put the little drain hole in rubbe boot on stater cable. Was obvious what was happening when I pulled off the boot for the first time. Yep, rusty connection do to water. Electric grease works fine also. Wonder if the Yamaha starter relay is stronger than the stock Hitachi? It was a common switch to make on my Aprilia Falco to replace stock relay with the Yamaha one for better "umpphh". Not electrical type so don't know where to get specs to compare both of the relays.
Thanks for the help.
Users browsing this forum: No registered users and 34 guests
