ducatipaso.org • View topic - STARTER MOTOR?
It is currently Wed Oct 01, 2025 9:53 am
 Post subject: STARTER MOTOR?
PostPosted: Sun Jan 24, 2010 8:04 am
:( High guys, yes im still having start problems it seems with the constant turning the motor over to check out my spark problems it now does not turn over when pressing starter switch. So I took solenoid to be tested ok, also checked ignition switch, cleaned contacts. battery also fully charged and will turn over when solenoid is crossed with srewdriver, so I just want ask the question where to now :wacko: as I seem to spend more time fixing this lemon :twisted: than I do ridding it. So where to now :banghead: and thanks to those who continue to put imput into this most helpfull site :thumbup:
 Post subject: Re: STARTER MOTOR?
PostPosted: Sun Jan 24, 2010 9:18 am
Did U measured with multimeter that 12V is coming TO solenoid primary circuit when ignition is on, kill switch is RUN position and U push start button? U told that it works when put screwdriver over solenoid, so, if it then turns starter normally, no need to open starter. To turn engine starter have to had:
1. +12V from starter button to PRIMARY CIRCUIT of solenoid (U can measure it by multimeter esily)
2. +12V from battery to input terminal of solenoid SECONDARY CIRCUIT AND when 12V is coming to primary circuit, then also 12V have to be in output terminal of solenoid=> 12V goes to starter motor and turns engine. (easy to measure with multimeter)
3. IF U have still that very bad Lucas solenoid, its earthing must be also OK, as it groungs via its cover/case to ground. (easy to measure again with ohm scale with multimeter).
I throw away that Lucas long time ago and put Hitachi solenoid from newer Ducati modells(need small modification to primary circuit connections). No problems since with 750 solenoid. Hitachi neeeds own earth to primary circuit. 907IE have that Hitachi unit.
If starter motor is gone/blown/brushes worn out, then only way is to open left side cover of engine, as starter have 2 screws outside and one(!!!) from inside engine. Somebody have changed brushes without opening left side of engine, but it needs really small/young flexible fingers... :mrgreen:
PostPosted: Sun Jan 24, 2010 9:32 am
PostPosted: Sun Jan 24, 2010 3:51 pm
These old Ducati aren't as reliable as the contemporary Hondas, but I wouldn't say they are lemons :mrgreen: :mrgreen: :mrgreen: .
They need much more care, above all with the electrics which need to be dry (with dielectric grease) and with no sign of corrosion over the connections.
So, if you fix those little things, you'll have no more too much issues.
PostPosted: Sun Jan 24, 2010 4:00 pm
Crusher, as You see, also Frankie start to be soon electrician! :mrgreen: :thumbup:
PostPosted: Sun Jan 24, 2010 4:05 pm
I'm the real LEMON :lol: :lol: :lol: :lol:
PostPosted: Mon Jan 25, 2010 2:33 am
Users browsing this forum: No registered users and 65 guests
