ducatipaso.org • View topic - 750 Paso Wiring Upgrade to Improve Starting
It is currently Fri May 01, 2026 7:16 pm
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Wed Aug 24, 2005 2:32 am
PostPosted: Sun Oct 09, 2005 3:02 pm
PostPosted: Wed Oct 12, 2005 10:39 am
PostPosted: Wed Oct 12, 2005 11:11 am
PostPosted: Wed Oct 12, 2005 12:01 pm
PostPosted: Tue Nov 21, 2006 11:55 pm
PostPosted: Sat May 05, 2007 1:08 am
PostPosted: Sun May 06, 2007 11:15 am
 Post subject: Re: 750 Paso Wiring Upgrade to Improve Starting
PostPosted: Mon Oct 12, 2009 11:13 pm
My 88 750 Paso wont Start, battery is fully charged, all I get is a click click sound... However when I push the bike and pop it into 3rd gear she starts right up. Could it be my starter or starter solenoid gone bad ? By the way where is the starter located on my 750 Paso ?
FL[/color]
PostPosted: Mon Oct 12, 2009 11:39 pm
PostPosted: Sun Sep 26, 2010 2:56 pm
Hi Jon,
I'm in the process of doing the wiring upgrade and so far it's all going to plan. Bit of a drama finding 12 gauge (3 mm2) wire but I'm getting there. It's moving a bit slower than I'd like but that is also due to the fact I'm cleaning all the connectors while I'm working on the wiring. And they certainly need cleaning... :lol:
I have a question about the diagram of the relay terminals in the how-to document. The text states to put the brown wire coming from the fuse panel to terminal #30 and the power feed with the 30Amp fuse to terminal #87. However, the diagram of the relay at step 9 shows it the other way around. I'm assuming that it makes no difference in the end ( when the switch closes the two wires are connected) but I'd just like to make sure.
Mike
