ducatipaso.org • View topic - What battery do you have?
It is currently Sat Mar 21, 2026 9:44 am
 Post subject: What battery do you have?
PostPosted: Fri May 15, 2009 2:03 am
All have the recommended 19Ah/12V?
No starting/turning over/charging troubles?
And you, Antti, our electric expert :thumbup: , what battery do you prefer & any opinion about ACC (cranking power)?
 Post subject: Re: What battery do you have?
PostPosted: Fri May 15, 2009 11:13 am
Odyssey PC535
- Kurt
PostPosted: Fri May 15, 2009 2:16 pm
Did you choose that, kurt, and if so, why?
Also thinkin bout odyssey, does it fit org battery box?
You have a pic of it mounted?
PostPosted: Fri May 15, 2009 7:40 pm
PostPosted: Fri May 15, 2009 7:51 pm
- Kurt
PostPosted: Sat May 16, 2009 7:55 am
Yuasa YB 16-B on older 907 and a cheap unit on the newer 907.
I disconnect the battery every time I think do not use the bikes for more than 2/3 weeks.
I have also an Accumate charger which I never used keeping on the bikes.
No matter, the next batteries will be the Odyssey.
PostPosted: Tue May 19, 2009 4:18 am
Hi Gert and Paso Fans,
I use a Deka ETX16 with a CCA of 275. It is a maintenance free seal acid battery with abscorbed mat technology – what ever that means. It has the positive terminal on the correct side.
It works well all through winter with out needing a re-charge or top up. Heaps of cranking power. Not that my 907 needs much cranking, it seems to start like clock work.
I went to a sealed battery, because I was finding small white stains on the swing arm and back wheel (bare aluminium). In the end I found there was a slight dribble coming from the battery breather hose. Must have come out when cranked right over on those fast left handers! - probably more like too much fluid.
So I would get my rags and polish them out. But I thought I would rather be riding it instead!
Anyway the battery was old and weak so I replaced with the above mention one and haven`t looked back.
PostPosted: Tue May 19, 2009 11:04 am
Thx f info, davo.
Been looking at Deka since it is locally avaliable.
PostPosted: Tue May 26, 2009 7:20 pm
When I need a battery for my 907 I take it to my local Harley dealer and let them match it up with an AGM for a... Softail? I'm not sure what mopdel it is, but it's an AGM and costs about $70 (2-3 years ago). Exact same size as the stock battery. Much more robust than a flooded acid type battery.
I still manage to kill them pretty regularly though (every couple years) mainly because I don't ride the bike much and I'm not the best at preventative maintanence...
-Craig
PostPosted: Wed May 27, 2009 6:35 pm
Craig, buy "clever battery charger" and You can run much longer with Your batteries... :mrgreen:
PostPosted: Wed May 27, 2009 6:56 pm
here's a charger for $25
http://www.batterymart.com/p-xciter-5-s ... arger.html
- Kurt
PostPosted: Thu May 28, 2009 11:09 am
I use an Optimate on my bike(s) alternating them every couple of days ( no pun intended! ) - which keeps them in near perfect condition. The clock and the alarm drain the 907's battery after about 10 days and once drained (dead) most batteries will not fully recover.
My other bike is a Triumph Sprint 955 and last up to 6 weeks without a charge !! British electrics!! :thumbup:
Rogero
1992 "Red" 907 I.E.
PostPosted: Thu May 28, 2009 11:10 am
Rogero
1992 "Red" 907 I.E.
