ducatipaso.org • View topic - changing rear caliper
It is currently Wed Oct 01, 2025 2:56 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: changing rear caliper
PostPosted: Mon Apr 20, 2009 12:48 pm
Gents, I'm getting ready to convert to 180/60 zr16 tyres, but it seems the bracket of the rear caliper is going to be a problem. In the past I've seen paso's with the caliper on the other side of the swingarm (downside). Only question is how to mount the bracket to the swingarm/frame. This to keep the caliper from spinning around..! :mrgreen: Anyone experience..?
cheers Léon
 Post subject: Re: changing rear caliper
PostPosted: Mon Apr 20, 2009 1:02 pm
how can there be a problem with the rear brake if you only change the tire ?
PostPosted: Mon Apr 20, 2009 1:10 pm
What he said! The brake is inside the radius of the tire.
PostPosted: Mon Apr 20, 2009 2:07 pm
I dont understand now (i think same way, as "G"), as caliper is very far from wheel ???? How caliper can hit to new tire, but not to old tire(Michelin)??? Maybe i am very stupid now... :wacko: Maybe again some misunderstood... :shock:
PostPosted: Mon Apr 20, 2009 6:29 pm
sorry Jon, I don`t get it. If I use the standard rim I can use any tire and will never have a problem with the rear brake. Isn`t the brake always inside the radius of the wheel/tire ? *headscratch*
PostPosted: Mon Apr 20, 2009 8:38 pm
G,
I was agreeing with you. The caliper is where you say it is. INDSIDE that radius...
PostPosted: Mon Apr 20, 2009 9:23 pm
PostPosted: Mon Apr 20, 2009 9:50 pm
:wacko: :wacko:
Brutus, A lot of people have trouble to get the wheels in line, because the bike behaves better.
and you are making a lot of trouble to get OUT of line??? to have a bike which walkes like a dog :lol: :lol:
on which planet are you on?? must be somewhere behind Pluto or something.
I'm gonna drink an extra glass of wine, because I had good laugh this evening.
Thank you very, Brutus. You're fun.
Ducbertus (Brrutus)
PostPosted: Mon Apr 20, 2009 10:01 pm
PostPosted: Mon Apr 20, 2009 10:07 pm
:beer:
PostPosted: Tue Apr 21, 2009 1:56 am
G'day Brutus
Please reconsider your decision to alter the position of your back wheel.There has been many ideas and suggestions discussed on this forum about changing tyres and the associated work that has to be done to make them fit,I think your idea has to be the worst option.I have just completed my tyre mod viewtopic.php?f=2&t=3191 and I found it to be rather easy to do and the wheels are still in line which is best,unless your a BMW owner. :wacko:
Cheers Ken
PostPosted: Tue Apr 21, 2009 3:22 am
I think your time and energy will be much better spent by going to 17" wheels. The Paso you showed is a 17" conversion. (GSXR wheels?)
I find it hard to believe that any motorycycle would have their wheels out of line of eachother. That BMW photo is simply a bad photo. I can take a similar photo of my bike, showing the offset on either side. You can't tell if they offset the rear wheel or not, and I have a hard time believing that they offset it at all. A bike like that rides funny. Its very easy to try out. Just adjust your rear tire so that it is close to touching the swingarm on one side and go for a ride. You will notice the difference. Tire wear is dramtically increased with tires out of line also. Probably not something you want when they are hard to get in the first place.
Spend your time putting on 17" wheels and be happy with a good tire selection.
Now engines have been offset I know, Like my 750 Sport.
PostPosted: Tue Apr 21, 2009 6:47 am
Gents, I know the offset-option is not the perfect way to go, but it's better then a wrong driveline. I checked once again and it seems that for example the santamonica's (late '80s) had an offset rear wheel 11mm. Offcourse is a perfect setting of the wheels still the better option.. Just proving my point :cool: :cool:
PostPosted: Tue Apr 21, 2009 7:59 am
Hi Brutus,
I've had my wine and now sober again. :cool:
putting the wheel off center is a way I wouldn't go.
BMW put their compleet drive train out of center to adapt wide section tyres. But the wheels itself stayed inline.
the chainline is also important. if you have the possiblity to move the rearsprocket more outside, you probably can make a special frontsprocket with the same offset as th rear sprocket. If you want to weld the frontsproket be aware that not all kind of steel good weldable. for instance C45 is widely used for sprockets, but not very good to weld.
An other solution could be to mount the 180 tyre and cut off the rubber that hits the chain.
those 5 or 6 mm of the surface edge are not the most important. But the sidewal must be untouched.
I'm curious to your final solution, Brutus.
Ducbertus
PostPosted: Tue Apr 21, 2009 8:12 am
Users browsing this forum: No registered users and 73 guests
