ducatipaso.org • View topic - 750SS sprockets
It is currently Mon Sep 29, 2025 5:44 pm
 Post subject: 750SS sprockets
PostPosted: Sun Mar 01, 2009 3:38 pm
Theres one thing I'm having a hard time dealing with this bike is the gearing, it's grossly over geared at least for my use!!
It has a 14/37 sprocket combo which makes the bike happy only at high revs/speed. In low gears/slower speeds it "bogs" and "snaps" the chain. 1st gear is extremely short!
Not being a young lad anymore my wheelie, 100+ mph, knee scraping days are over (too chicken for that stuff now :cool:) , I'm more into city/work commuting and the "slow" enjoyable rides ... ;)
So what do u guys suggest:
1- front or rear sprocket change or change both?
2- what do you think of a 39 or 40 teeth rear sprocket with the 14 front?
3- will I need a new chain with a 14/40 combo?
Best rgrds, ride safe!
1992 Ducati 907 IE
1993 Ducati 750 SS
2006 Harley Davidson Sportster
2008 Harley Davidson ElectraGlide Classic
 Post subject: Re: 750SS sprockets
PostPosted: Sun Mar 01, 2009 4:42 pm
the original front sprocket is one with 15 teeth
PostPosted: Sun Mar 01, 2009 4:46 pm
I'll double check, could have missed a tooth, but it seemed to be 14 ...will update asap ...thanks
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Sun Mar 01, 2009 5:09 pm
could be that the last owner changed it. There are aftermarket 14 teeth sprockets, at least this would explain the behaviour you mentioned. My SS repair manual says original is 15/37.
PostPosted: Sun Mar 01, 2009 5:37 pm
15 / 40 on my Sport with 17" wheels and 5 speed.
The 900ss is a six speed, so first can be geared lower without loosing top end.
750 motor is 5 speed, so there is some compromise.
PostPosted: Sun Mar 01, 2009 6:21 pm
Not concerned with top end as I usually cruise at 70mph~75mph max.
Need smoother low speed/city driving gearing, specially 1st gear which is borderline ridiculous.
I've heard getting a 15 front sprocket is not easy so what can I expect from a 14/39 or 14/40 combo?
Can I keep my actual chain with these combos as it is in good condition?
thanks
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Sun Mar 01, 2009 6:37 pm
PostPosted: Sun Mar 01, 2009 6:49 pm
got the link to that auction? USA? EU?
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Sun Mar 01, 2009 6:53 pm
EU (PMed you the link)
PostPosted: Sun Mar 01, 2009 6:56 pm
CORRECTION...front sprocket IS a 15 ..go figure I missed one tooth on my first count.
You were right Paso750!
So, talk to me guys how about a 15/40 combo for the '93 750SS will that alleviate my problems??
Thanks!
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Sun Mar 01, 2009 9:22 pm
So you are running 15/37, which is the original configuration. I was running my SS 750 with the same gearing. 15/37 is definitely too long.
The best compromise would be 15/39. (Thats the gearing I use on my 888)
Greeting from Germany
Volker
PostPosted: Fri Mar 06, 2009 2:26 pm
Throw a 14 tooth on the front and adjust the chain. It will solve your problems the easiest, cheapest way.
Buy one at http://www.ca-cycleworks.com/shop/catal ... chain.html
Users browsing this forum: No registered users and 88 guests
