ducatipaso.org • View topic - upgrading desmodue to dual spark!
It is currently Thu Jun 18, 2026 3:53 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: upgrading desmodue to dual spark!
PostPosted: Mon Feb 23, 2009 9:07 am
PostPosted: Mon Feb 23, 2009 12:51 pm
No electrics at all.
PostPosted: Mon Feb 23, 2009 12:59 pm
does that mean it isn`t mentioned or he didn`t do it ? If ignition timing isn`t changed the motor will not live very long as sooner or later there will be a piston damage. You need to modify the flywheel or get a programmable ignition module (standard ignition timing is 34° full advance and usually needs to be changed to 26, 28° or 30° with dual spark plugs depending on compression ratio and if it`s a bike originally equipped with a Kokusan or Digipley ignition)
PostPosted: Mon Feb 23, 2009 2:14 pm
He says there was any modification except for the exhaust pipes and for the setting of the carburettors by a Dynojet st2 kit.
No mention about the ignition.
PostPosted: Tue Feb 24, 2009 7:16 pm
I'm thinking this might be a good beginning for an overboosted engine :thumbup:
PostPosted: Wed Feb 25, 2009 9:39 am
PostPosted: Wed Feb 25, 2009 6:18 pm
Actually I've seen an 851 engine with turbo supercharger and marelli ecu from a fiat uno turbo 1300cc, but I was meaning a volumetric supercharger such as EATON ones
(here's the site of an italian tuner)
Wonder how mutch torque can a 904 engine bear! :evil: :evil: :evil:
PostPosted: Thu Feb 26, 2009 11:56 am
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Why do butcher those ancient bikes????
I'm already trying to convince my 906 friend to not fit an ST4 engine on his bike....
PostPosted: Fri Feb 27, 2009 6:36 am
PostPosted: Fri Feb 27, 2009 7:45 am
Some magazine (both modern and ancient) sometimes tells crap...
PostPosted: Fri Feb 27, 2009 2:00 pm
The US site talks about retarding the timing but the spec is unreadable :roll:
PostPosted: Fri Feb 27, 2009 6:28 pm
Maybe electrex has a special mapping for desmodue?
Otherwise "pederzini" black boxes step 6 or 7 can do
PostPosted: Tue Mar 03, 2009 4:36 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Tue Mar 03, 2009 6:00 pm
The friend of mine can't do the work by himself, so I guess such work can be very, very expensive...
Besides, many problems could be got over fitting an 851/888 engine, that would fit very well into the Paso frame.
But, all in all, I don't know how much is worth such project...
The Paso's frame doesn't tolerate the 4 valves power and has to be strengthened.
PostPosted: Wed Mar 04, 2009 2:29 am
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
