ducatipaso.org • View topic - Repairing a Digiplex
It is currently Wed Jun 17, 2026 1:49 am
 Post subject: Repairing a Digiplex
PostPosted: Tue Oct 14, 2008 8:28 am
Digiplex on my Paso 906 did not work correctly cause to intermittent problem on vertical cylinder ignition. :cry:
Therefore, I have opened the box and I have detached all connections from circuit to the framebox.
Inside it I found the circuit completely covered with a protective rubber plus 2 big transistors. I suppose the problem was one of final power transistors. I frozen over/around it with electronic circuit refrigerant gas and immediately the vertical cyl begin to run.
Quickly, I run to buy two new transistors (BU931ZP – price € 4.50), replaced it but, with great disappointment, the vertical cyl did not work fine. :cry:
Therefore, without fear, I began to remove delicately, with a toothpick, the rubber from the circuit. :mad:
I found few electronics components under the rubber and many great lines from the transistors to external pin 10 11 12 (pin towards the coils).
When I freeze one of this lines, vertical cyl begin to run. :lol: :lol:
Sure and happy to have solved the problem, I have solder bridge from transistors (which one link to pin 11 - vertical cyl) to external pin and all it has worked. :thumbup:
I Am much happy, Ciao a tutti
P.S. in the afternoon I post same photos
 Post subject: Re: Repairing a Digiplex
PostPosted: Tue Oct 14, 2008 9:20 am
Well done, thx f sharing!
Looking forward to pics.
PostPosted: Tue Oct 14, 2008 6:55 pm
PostPosted: Tue Oct 14, 2008 11:39 pm
This shows the lenghts folks will go to keep their Pasos running.
Help and electrical fool understand something. Why does freezing the circuit make it work??
PostPosted: Wed Oct 15, 2008 8:56 am
PostPosted: Wed Oct 15, 2008 9:59 am
:thumbup: , FAQ material!
Do you have a wiring schematics of the Digiplex as well?
PostPosted: Wed Oct 15, 2008 12:58 pm
PostPosted: Wed Oct 15, 2008 5:24 pm
So how did you know to make additional wire in pic 2?
PostPosted: Wed Oct 15, 2008 6:57 pm
PostPosted: Wed Oct 15, 2008 8:43 pm
Sorry, this is a complete Digiplex pic (by internet)
Transistor are under vacuum device.
transistor location, green line are the original bridge to carry hi current
original bridge
PostPosted: Thu Oct 16, 2008 12:00 am
Thx again!
We can probably run our Paso`s forever when guys like you chime in... :)
Do you work w electronics f a living?
PostPosted: Thu Oct 16, 2008 6:34 am
So, if it only was a circuit fault, it could be quite easily redone for a perfect recover...
Great job!
