ducatipaso.org • View topic - 907 swingarm on 750
It is currently Wed Oct 01, 2025 1:29 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: 907 swingarm on 750
PostPosted: Fri Dec 14, 2007 1:12 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Sat Dec 15, 2007 4:55 pm
year: 1985
I found an axle from a monster 600 the diameter is ok 17mm,but the seller says to me that the lenght is 33 cm....
you wrote that i need 35 cm of total axle lenght :shock: :shock: ....my question is:
he takes wrong measurement?cause the stock monster swingarm seems to me identical in the end part to 907 one....
i hope it should be fit :)
lamps
Piero
P.S.
do you think chain register of monster 600 will fit??? :mrgreen:
PostPosted: Sun Dec 16, 2007 5:11 pm
M600 has 4,5" rear wheel & a steel swing, thererfore the difference
in axle length I think. M900 w alu swing axle would fit as they have the same
rear wheel as 907.
PostPosted: Tue Dec 18, 2007 2:11 pm
year: 1985
:shock: :shock: :shock: :shock:
iìm so confused because i have at home 4.5 wheel and i supposed to mount a 170/60-17 on it....but the internal diameter for axle is 17 mm,now if the axle for monster an supersport 600-750 are too shorter i hav to buy one from an St or a 900 monster with alu swingarm....and if the axle of this bike will be too big for my rim??? :oops: :oops: :oops:
what do you think??
lamps
Piero
PostPosted: Tue Dec 18, 2007 2:27 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Tue Dec 18, 2007 10:08 pm
Hey guys
Found this site with a 17" conversion. Looks neat.
http://alltomingenting.no-ip.info/gallery/new_rear_axle
Regards
PostPosted: Wed Dec 19, 2007 1:17 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Dec 19, 2007 2:19 pm
It is a M8. I have a PDF file of the drawing. I can send it to you. Or you can look at this link http://alltomingenting.no-ip.info/paso/Excenter
Regards Klaus
PostPosted: Wed Dec 19, 2007 3:16 pm
Seems, that link doesnt function... :oops:
PostPosted: Wed Dec 19, 2007 3:17 pm
PostPosted: Wed Dec 19, 2007 8:09 pm
Hi Anders
Is it you’re PASO on http://alltomingenting.no-ip.info/gallery/new_rear_axle ? It looks great with conversion. Have you had any issues? What about clearance between the wheel and swing arm?
Klaus
PostPosted: Wed Dec 19, 2007 9:00 pm
Yes,
It's mine.
Clearence are very tight.
Chain alignment was tricky.
The wheel I got was not centered in same way as the Paso.
Needed to make some special spacers.
The excenter is available from a UK manufacturer.
But I had it made localy.
//Anders
Now with Megasquirt EFI!!
PostPosted: Wed Dec 19, 2007 9:18 pm
What about the depth clearance. I mean does the diameter of the wheel produce a problem. I noticed that the eccentric is at it outer position?
Do you remember where or who in the UK
Klaus
PostPosted: Wed Dec 19, 2007 9:39 pm
Yes,
The wheel dia is a matter. The exenter have to be in back position, otherwise the tire will scrubbing against the front of the swingarm.
I have Pirelli Diablo 160/60 tiresback.
The bike runs more smooth with 17" tires.
//Anders
PostPosted: Thu Dec 20, 2007 4:50 pm
Here is the link to the UK manufacturer,
and a view of the excenter they make,
Their produced swingarm on a Monster in Sweden,
//Anders
Users browsing this forum: No registered users and 50 guests
