ducatipaso.org • View topic - Swing arm damage, can I weld it?
It is currently Sat Mar 07, 2026 12:51 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Swing arm damage, can I weld it?
PostPosted: Fri Nov 02, 2007 12:07 pm
I removed the rear wheel and noted that the rear sprocket was very loose. Is this normal on a neglected bike? On closer inspection I found that all five bolts holding the rear sprocket to the wheel had come so loose and that they had worn a groove of about 3 mm deep into the swing arm. I don't know how the pervious owner didn't notice this grinding noise but I don't think it would have been too long before they noticed as two of the five bolts were finger tight and the other three were almost at the end of their locking threads on the nuts.
Anyway, should I get the groove left from the bolt heads, filled with weld or should I try and source a new swing arm? Any suggestions??
PostPosted: Fri Nov 02, 2007 12:52 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Thu Nov 15, 2007 9:38 am
PostPosted: Thu Nov 15, 2007 10:09 am
 Post subject: Re: Swing arm damage, can I weld it?
PostPosted: Sat Nov 24, 2007 12:44 pm
what? this one?
http://cgi.ebay.co.uk/Ducati-Paso-907-i ... dZViewItem
PostPosted: Sat Nov 24, 2007 1:26 pm
That is a 907 one.
No matter, it would be a great start for the 17" wheels conversion.
Now, it seems there is no Paso swingarm on eBay, even if sometimes they appear on it.
PostPosted: Sat Nov 24, 2007 8:46 pm
Damaged swingarm, it´s only aluminium, shouldn´t be any broblem welding it. Only
if you can´t do it yourself let a good welser do it. :mrgreen: Krakan 907 Red
PostPosted: Sun Nov 25, 2007 8:19 am
A good craftsman will do it in a few minutes.
It's enough he fills the notchs with the aluminium.
Later you'll grind away the surplus, until you'll get the right shape to the swingarm.
I made the same thing, when I had the 906. After I fell down, the swingarm was notched by the bent of the footpegs.
Many Pasos have the same dents on the swingarm.
PostPosted: Sun Nov 25, 2007 9:30 am
...and also acid leak from battery breather pipe, when/if bike have fallen... :?
PostPosted: Sun Nov 25, 2007 12:36 pm
Mine is both dented and spotted...
Is there a way to remove that spots without polishing the aluminium?
Or better, since I don't like too much the polished aluminium, is there the way to have the aluminium surface satinized as the original finishing?
Some kind of brush?
PostPosted: Sun Nov 25, 2007 7:00 pm
No! If surface have failed, only way is to make again that anodic/cathodic coating! You can polish stainless steel very easily, alumium little harder, but if its damaged, that cant fix by polishing anymore... :twisted:
PostPosted: Sun Nov 25, 2007 7:59 pm
PostPosted: Mon Nov 26, 2007 1:55 am
Anodizeid coating.
Like when you colour alu parts & other materials red, blue etc w a thin electro/chemical coating bath. You dip the parts in this and you get a thin protective surface in colour if you like.
I have welded my swing on my Monster w a similar swing.
Some 5 years ago now, no problemo.
PostPosted: Mon Nov 26, 2007 1:48 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Nov 26, 2007 2:42 pm
