ducatipaso.org • View topic - Fan does not stop
It is currently Fri Jun 19, 2026 5:41 am
 Post subject: Fan does not stop
PostPosted: Mon Sep 17, 2007 12:54 pm
PostPosted: Mon Sep 17, 2007 4:55 pm
PostPosted: Wed Sep 19, 2007 5:13 pm
I have a fully electronic controller for my fan because I run my Paso with two radiators so have had to ditch the standard bi-metallic switch. The circuit is a modified Velleman thermostat and I can vary the switch on temperature along with the switch on at - switch off at - setting (hysteresis).... But it took a bit of doing.
PostPosted: Wed Sep 19, 2007 5:26 pm
"JWilliam": I am very courious, HOW You did it, so can U explane more? :confused: I added to my 907IE 2 extra small fans with normal switch in right handlebar to put more fans on, if driving in hot conditions in cities with low speed. When speed is higher, then it automatically cools engine more, so then i switch off those "extra fans"... :evil: Btw, do You have 906, or 750 Paso?
PostPosted: Thu Sep 20, 2007 9:32 am
Well I wouldn't be running a water cooled 750!, its a 906. When you say you are curious, do you mean the second radiator or just the electronic fan control?
PostPosted: Thu Sep 20, 2007 12:21 pm
PostPosted: Fri Sep 21, 2007 12:15 pm
PostPosted: Fri Sep 21, 2007 12:25 pm
PostPosted: Sun Sep 23, 2007 11:12 am
PostPosted: Mon Sep 24, 2007 3:22 pm
PostPosted: Mon Sep 24, 2007 6:16 pm
PostPosted: Mon Sep 24, 2007 6:40 pm
PostPosted: Tue Sep 25, 2007 2:56 pm
PostPosted: Wed Sep 26, 2007 4:51 pm
Thanks a lot...does anybody know if the temp switch has two electric connections or just one? all the best and keep on riding, hardo
PostPosted: Fri Sep 28, 2007 3:49 pm
