ducatipaso.org • View topic - 907 sprocket ??
It is currently Mon Mar 09, 2026 5:47 pm
 Post subject: 907 sprocket ??
PostPosted: Fri Aug 17, 2007 1:29 am
anyone know offhand how many teeth on the OEM rear sprocket for the 1991 907s?
thanks
PostPosted: Fri Aug 17, 2007 9:32 am
40 according to the FAQ here.
PostPosted: Fri Aug 17, 2007 10:22 am
Mmmm...if I go to a 37 teeth, anyone done this mod?
You guys think it's worthwhile? How about top end?
The bike has Staintune cans, K&N a/f, and chip.
I'm actually happy with it's performance as is, just considering the sprocket swap.
Thanks!!
PostPosted: Fri Aug 17, 2007 12:07 pm
PostPosted: Fri Aug 17, 2007 1:28 pm
PostPosted: Fri Aug 17, 2007 2:00 pm
PostPosted: Fri Aug 17, 2007 7:26 pm
PostPosted: Sat Aug 18, 2007 6:00 am
I'm looking to lower the revs when doing 60+ mph so I guess a 42 would be my best bet?
PostPosted: Sat Aug 18, 2007 10:46 am
What gearing have you had until now?
If you`ve had less than 42 rear it will rev more at 60 w it.
PostPosted: Sat Aug 18, 2007 2:06 pm
right now I have the stock, original gearing so I figure if I go with a 42 it should be LESS revs at 60mph for example. Correct?
PostPosted: Sun Aug 19, 2007 10:36 am
No. Bigger rear = higher RMP at 60.
42 higher revs than 40.
 Post subject: stock/modified gear ratios
PostPosted: Tue Sep 11, 2007 1:37 pm
'91 907ie (Red)
'93 907ie (Red)
'93 907ie, w/ worked engine (Red)
'07 1098S (Red)
'07 MV Agusta F41000R
'82 Kawasaki KZ1100 Spectre (Wine/Black)
PostPosted: Tue Sep 11, 2007 2:11 pm
PostPosted: Tue Sep 11, 2007 9:51 pm
PostPosted: Tue Sep 25, 2007 6:59 pm
