ducatipaso.org • View topic - FIM chip install
It is currently Tue Mar 03, 2026 5:13 am
 Post subject: FIM chip install
PostPosted: Sat Aug 18, 2007 6:04 am
I have a FBF chip, I don't have a instruction sheet but it certainly looks like a simple straightfoward install.
Anything special or in particular that I need to look out for?
Any tips or suggestions for a "safe" install?
Thanks!!
PostPosted: Sun Aug 19, 2007 1:13 am
Mmmmm...anyone? Anything?
PostPosted: Sun Aug 19, 2007 7:01 pm
Ground YOURSELF with some copper wire to bikes ground before installation to avoid any electrical chock to eprom(or to ECU)! Then make note, in what end of old EPROM is that "notch". Take it away carefully and then put new to same way(that notch). Be carefull to take old away with some modified screwdriver, etc. DONT SHORTCUT ANY pins of eprom with any tools! :thumbup:
..."helppoa, kun heinän teko"... :laugh:
PostPosted: Sun Aug 19, 2007 8:20 pm
PostPosted: Mon Aug 20, 2007 6:22 pm
PostPosted: Tue Aug 21, 2007 1:33 am
[quote]Anything special or in particular that I need to look out for?
Any tips or suggestions for a "safe" install? [quote]
Some small things:
Did it today. Just be gentle, if you don`t have the special pliers for it. Main thing, DO NOT bend the legs of the chip and you`re good to go! I lifted the chip w a long, small screwdriver and a 1,5mm wire at the other end at the same time. Think of your body`s most delicate part and handle the chip w that in mind.... :thumbup:
Adjusting CO and checking A/F ratio afterwards is a good thing to be safe.
PostPosted: Thu Aug 30, 2007 8:56 pm
The FBF chip installed and what a difference!!
The bike pulls so strong and smooth it's like a different bike! even sounds a bit different mostly at WOT.... :lick: :lick: :lick:
PostPosted: Fri Aug 31, 2007 11:56 am
:thumbup: :thumbup: :thumbup:
