ducatipaso.org • View topic - No oil , charge light,
It is currently Fri Dec 19, 2025 9:18 am
 Post subject: No oil , charge light,
PostPosted: Tue Jun 26, 2007 4:17 pm
On my new to me 88 Blue Paso the oil and charging lights do not work. I cleaned the contacts on the back side of the instrument panel. I am not getting any voltage to them, I check with a meter.
I got all the other lights to work with a good cleaning. Any Ideas,those are the two lights I would like to have.
PostPosted: Tue Jun 26, 2007 5:26 pm
I happened to have the +12v "line" broken in the circuit in the backward of the instrument panel.
Anyway, you can try to put the plug pon the oil bulb in contact straight to the frame (12v ground). This will tell you something about bulb and ground wire
PostPosted: Tue Jun 26, 2007 6:25 pm
That printed circuit behind dashboard can broke quite easily, but all contact surfaces in it must be out of all oxygen and totally clean. U can use multimeter in resistance scale to check continuty. Remember to clean well those bulb contact areas and easy to check also those bulbs in resistance scale. :thumbup:
PostPosted: Wed Jun 27, 2007 11:56 am
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Wed Jun 27, 2007 12:41 pm
 Post subject: Charge light
PostPosted: Thu Jun 28, 2007 12:05 am
The charge light does not work because that voltage regulator does not have a provision for it. That regulator was recommended to me by BCM in Laconia when the stock one failed. I figured it was a small sacrifice for a more dependable unit. Sorry, I had forgotten all about the light.
PostPosted: Thu Jun 28, 2007 1:46 am
Thanks Paul. I forgot you had mentioned that.
You would have gotten a good chuckle when the Paso started, it blew sunflower seeds like a confetti gun out of the mufflers. Guess you have a couple of mice in the garage. :laugh:
PostPosted: Fri Jun 29, 2007 12:37 am
I learned my lesson when a mouse got into the glove box of the AMX. :mad: I now have traps loaded and ready to prevent further damage.
