ducatipaso.org • View topic - To FIM or not to FIM...
It is currently Wed Oct 01, 2025 7:26 am
83%  83%  [ 5 ]
17%  17%  [ 1 ]
Total votes : 6
 Post subject: To FIM or not to FIM...
PostPosted: Tue Jun 19, 2007 12:27 am
PostPosted: Tue Jun 19, 2007 12:29 pm
You can find all the info about the FIM chip in their website.
http://www.fuelinmoto.com.au
There is a specific chip for the 907.
Here there are the results.
PostPosted: Wed Jun 20, 2007 3:29 pm
PostPosted: Sat Jun 23, 2007 8:33 am
Are that 907 chart accurate? Seems pretty low which also the one f 851 is:
PostPosted: Sat Jun 23, 2007 1:27 pm
Those charts show the HP at the rear wheel!
PostPosted: Sat Jun 23, 2007 8:33 pm
PostPosted: Sun Jun 24, 2007 4:33 am
PostPosted: Mon Jun 25, 2007 9:41 pm
PostPosted: Tue Jun 26, 2007 4:24 am
Check that code from from ECU! Whats it???? I am quite sure, that U have P7 and U can use FIM EPROM normally in that P7, BUT IF U want to change mapping inside FIM eprom AND STORE THAT CHANGING to EPROM, then You need AMB. AMB keeps changes(made by FIM software with flat top!!!) inside ECU after You turn ignition key to OFF mode.... :evil: Without AMB P7 ECU cant remember changes! :thumbup:
PostPosted: Tue Jun 26, 2007 10:36 am
PostPosted: Tue Jun 26, 2007 12:18 pm
PostPosted: Tue Jun 26, 2007 2:01 pm
Gothenburg.
PostPosted: Tue Jun 26, 2007 6:09 pm
Ok! :thumbup: I have friends in Malmö :laugh:
P7 have these marks in label:
IAW 043 / 04
WU 43.07 / 20A_28
I have 2 x P7 ECUs and both have exact same label/marks :thumbup:
PostPosted: Tue Jun 26, 2007 11:55 pm
 Post subject: FIM Chips
PostPosted: Fri Jun 29, 2007 11:21 pm
I put in the Ferracci stage 1 chip when I put on my Cobra F1 pipes on my 1991 Paso 907ie and there was a noticeable improvement in performance. Has been running great for two year.
You can get the chips here: http://www.ferracci.com/store/cart.php? ... etail&p=98
