ducatipaso.org • View topic - Dashboard bulbs
It is currently Mon Sep 29, 2025 5:10 pm
 Post subject: Dashboard bulbs
PostPosted: Wed May 23, 2007 11:30 am
Today I started the bike and all the dashboard bulbs in the background didn't work :sad: :sad: :sad: , while the others dashboard bulbs worked (high-beam, indicators etc.).
I'm guessing the background dashboard bulbs are connected in line, so one is burn out.
Is it so?
PostPosted: Wed May 23, 2007 11:46 am
not in line, BUT parallel! Better U check, is there 12V in base of both bulbs? Some voltage peak can burn both same time. That have happened to me. Anyway very cheap normal glass base bulbs.... :thumbup: Btw, does all other light(parking lights, especially) function normally????
PostPosted: Wed May 23, 2007 3:12 pm
PostPosted: Wed May 23, 2007 5:22 pm
PostPosted: Wed May 23, 2007 7:36 pm
PostPosted: Wed May 23, 2007 8:20 pm
PostPosted: Thu May 24, 2007 7:09 pm
Those contact cleaners are safe to use in Your case. Dashlights function allways same time, as parking lights, so if U want parking lights work alone, then need some wiring mods, but its quite strange way....
PostPosted: Thu May 24, 2007 7:58 pm
I only want the dash bulbs work when the lights are on.
Perhaps, I spoiled the sliding switch...
PostPosted: Fri May 25, 2007 4:11 pm
Rogero
1992 "Red" 907 I.E.
PostPosted: Fri May 25, 2007 5:45 pm
PostPosted: Fri May 25, 2007 5:57 pm
Users browsing this forum: No registered users and 110 guests
