ducatipaso.org • View topic - Crack in fuel tank!
It is currently Thu Mar 12, 2026 7:35 pm
 Post subject: Crack in fuel tank!
PostPosted: Mon Jan 22, 2007 2:08 pm
Hi all, I went out in the shed to tinker with my
907 when the smell of gasoline met me in the door...
Looked everywhere, no leaks but a very strong smell
then removed gas tank and found a fine crack halfway
round the front support of the tank. Any tips of fixing
this without welding and destroying the paintwork.
:sad: :sad: :sad: Krakan
PostPosted: Mon Jan 22, 2007 4:02 pm
A thing like this happened to me when I had the 906.
The tank leaked from the rear support (near the seat) where there already are two stock welding.
The welder was able to fix it without any damage to the paint.
If, as I have understood, the crack is hidden, you will not have too much troubles to make weld it :thumbup: .
PostPosted: Tue Jan 23, 2007 8:56 am
 Post subject: 907 fuel tank on e-bay
PostPosted: Tue Jan 23, 2007 9:45 pm
mark,
if your talking about the brand new 907 fuel tanks that listed on e-bay last year, they did sell. i bought 2 of them on e-bay over the past year. shipping them to the usa was extemely expensive, increasing the cost of the tanks by more than 50%. they do appear on e-bay from time to time. since these 907 fuel tanks listings always seem to be in europe, the shipping to krakan in sverige will be considerably less than to me here in philadelphia, USA. krakan, try and find a new one if you can. a much better solution than welding the old one.
elton
 Post subject: Cracked tenk
PostPosted: Fri Jan 26, 2007 11:04 am
Hi all, my tank is cracked where the front support is welded
to the bottom of the tank, however the crack is very small and
i have sanded down the surface and covered it with epoxi glue
and painted the small repair with a primer and a humbrol red
model paint (a very close match in the colour) but nobody will
notice because it´s the underside of the tank anyway. I am going
to cover the inside of the tank with tank sealer and then hopefully
it will be no more gas smell. I will let you know how it goes. :thumbup: :thumbup: Krakan
PostPosted: Sat Apr 21, 2007 8:54 pm
PostPosted: Sun Apr 22, 2007 4:07 pm
-Craig
PostPosted: Tue May 01, 2007 1:18 pm
PostPosted: Tue May 01, 2007 6:25 pm
PostPosted: Wed May 02, 2007 10:37 am
PostPosted: Wed May 02, 2007 5:08 pm
PostPosted: Wed May 02, 2007 8:54 pm
year: 1985
PostPosted: Fri May 04, 2007 2:09 pm
PostPosted: Fri May 04, 2007 4:12 pm
PostPosted: Fri May 04, 2007 8:34 pm
