ducatipaso.org :: View topic - 906 engine block
ducatipaso.org
http://www.ducatipaso.org/forum/
906 engine block
http://www.ducatipaso.org/forum/viewtopic.php?f=4&t=5425
Author:  adysax [ Wed Jun 20, 2012 12:23 pm ]
Post subject:  906 engine block
anybody know where I can find a replacement drive side (left) engine block as mine has smashed after the chain snapped. see photo
DSCF0005.JPG [344.79 KiB]
Downloaded 442 times
Author:  900streetfighter [ Wed Jun 20, 2012 2:47 pm ]
Post subject:  Re: 906 engine block
You'll probably have to get a pair of cases or that might be repairable Where are you?
Author:  Tamburinifan [ Wed Jun 20, 2012 8:01 pm ]
Spotted one yesterday on us ebay,
think seller was guzzitech.
Author:  adysax [ Thu Jun 21, 2012 12:14 pm ]
Author:  higgy [ Thu Jun 21, 2012 8:11 pm ]
UK ? USA? AUS?
Author:  samandkimberly [ Thu Jun 21, 2012 8:43 pm ]
is that the only problem, and is it still in the bike? If so, repair it - cut/bend a piece of AL to fit the hole as best as you can, clean everything real well with lots of solvent, then sand/file everything nearby so that there is fresh, rough metal everywhere glue might end up. Glue in place with a good 24 hr epoxy - I've used MarineTex, PC7, and JB Weld all with good luck. If needed, build up a solid layer on top of the AL you cut to fit as thick as the original casting or thicker so the cover can seat - you can do this with more regular epoxy or you can use epoxy putty. Let sit for 2-3 days, then flat file the sealing surface down to the same level as the original machine work or even a little lower - you don't want the compressive forces of the cover working to break the epoxy bond. Seal it with a little silicon when you reassemble.
I've fixed much worse, and never had a repair like this fail, as long as proper attention is paid to the prep work.
Sam
Author:  adysax [ Wed Jun 27, 2012 9:10 am ]
Page 1 of 1 All times are UTC
http://www.phpbb.com/
