ducatipaso.org • View topic - Wich rims fit on a 907?
It is currently Fri Jun 19, 2026 2:44 am
 Post subject: Wich rims fit on a 907?
PostPosted: Wed Feb 23, 2011 4:12 pm
Hi Guys,
can you tell me wich Ducati-rims fit on a 907?
Does th 851-Rim fit? Or a SS-Rim?
/ Edith: is it correct, that these would fit?: SS/SL/M/851/888 in Front, and 400-900SS/SL,Mon in rear?
BR,
Johannes
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
 Post subject: Re: Wich rims fit on a 907?
PostPosted: Wed Feb 23, 2011 4:29 pm
you mean as 1:1 replacement ?
I guess that`s the question as generally you can use whatever rims you want with spacers etc.
PostPosted: Wed Feb 23, 2011 5:56 pm
As a 1:1 replacement, at first, yes.
Ok... monoswingarm types do not fit, thats clear.
And many are just "swappable"?
86` Ducati 750 Paso
PostPosted: Wed Feb 23, 2011 7:46 pm
rimsize 3.5 x 17
and Ø 17 mm axle size. this means Marzocchi or maybe early Showa upsd forks
so anything pre 1994 I would say
required spacers are easy to machine or obtain.
bertus
PostPosted: Thu Feb 24, 2011 10:57 pm
