It is currently Tue Mar 24, 2026 9:42 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: Proud new owner and member-ADVICE?
PostPosted: Fri Sep 18, 2009 12:00 am
I found these pipes on the web and contacted them. They do still make pipes for a 907. I know nothing about them though other than they are $890.00 US
http://www.cycleworks.co.nz/european.php
Preston
PostPosted: Sun Nov 01, 2009 5:51 pm
Yes that is my 907 in the video. The link below will tell you about my custom exhaust. The system is actually not that loud even when fully open without end caps in the system as shown in the video. It is comparable to the Termi's on my 916. If you add the end caps and fewer disks the decibel level is similar to a stock system. The reason I chose the Supertrapp was to be able to tune it however I like. With the Supertrapp you have many options. Good luck with your new Paso.
viewtopic.php?f=3&t=2550
1992 907ie Beauty. Custom high pipes, Pro Italia chip, Barnett performance clutch, Corbin Seat, Stainless brake lines. 35,000 miles. Owned since 1993.
