It is currently Tue Apr 28, 2026 10:38 am
[ 7 posts ] |
| Author |
ducinthebay
Post subject: Jetting for Dellorto PHM 40 Posted: Fri Dec 19, 2008 9:17 pm |
| paso grand pooh-bah |
I'm dropping a 900 motor into my 1990 Sport, and have aquired a pair of Dellorto 40 PHM carbs. What is the recommended jetting? Slides, needles, main, pilot, etc. Thanks,
BTW, For some odd reason you can buy PHM 40's for about $100 apiece on ebay. Search Husqvarna carburetor, or Husaberg carb. They fit the 501 and 601 engines. I have a couple headed my way. I'll let you know how well the carburate.
| Top |
jcslocum
Post subject: Re: Jetting for Dellorto PHM 40 Posted: Sat Dec 20, 2008 10:34 pm |
Would the jetting from a 900 monster be approximatley the same??? I may have that manual laying around.
| Top |
ducinthebay
Post subject: Re: Jetting for Dellorto PHM 40 Posted: Sat Dec 20, 2008 11:51 pm |
That will certainly get me close. I can figure it out from there. Thanks,
Phil
| Top |
guzzitech
Post subject: Re: Jetting for Dellorto PHM 40 Posted: Tue Jan 27, 2009 1:51 am |
This will get you in the ballpark. Check on a dyno or with plug checks top be sure. Adjust mains and/or needle position until it's spot on. I usually jet the rear cylinder one size (increment of 5) richer.
K4 needle, bottom clip 128 mains 68 idle 50/3 slide 265 atomizers
| Top |
ducinthebay
Post subject: Re: Jetting for Dellorto PHM 40 Posted: Wed Jan 28, 2009 4:36 am |
Thanks, The carbs I have now have 50/1 slides. What would be the difference in how they behave? Unfortunately, slides cost a lot for new ones, so I will try to make a go with the ones I have. ($70 each.) Stay tuned.
Phil
| Top |
guzzitech
Post subject: Re: Jetting for Dellorto PHM 40 Posted: Wed Jan 28, 2009 5:05 am |
You have 50mm cutaway slides, and so does that recipe. Only difference is accelerator pump ramps (/number). Ramp action is fairly inconsequential.
Further, most twins I have seen with big 40mm carbs will go way lean anyway when the throttle is whacked open suddenly (what the accel pumps are supposed to correct for). You have to crank acccel pumps way up for them to have any meaningful effect. ed
| Top |
dave906
Post subject: Re: Jetting for Dellorto PHM 40 Posted: Sat Oct 03, 2009 4:41 am |
Joined: Tue Apr 11, 2006 12:00 am Posts: 32 Location: Canberra, Australia
Hi Ducinthebay I have only just seen this post, but have some info that may still be of use. I have a 906 with PHM40 Delortos. They were installed and setup for me by Gowanlochs in Sydney Australia and seem to work pretty well.
The info here is from my notes last time I gave the carbies a clean and I am away from my bike for a few years so I can't check anything else at present. There are some similarities with Ed's post so suggests things are on the right track.
Main jet 152 (Vertical) 148 (Horizontal) (Vert cylinder runs hotter due to less airflow so richer jet) Needle K5 (clip on middle slot) Atomiser AB265 Idle Jet 68 Choke Jet 60 Pump Jet 45 Float weight 1gr 8.5 Float Needle valve 250 Float height 18mm Mixture Screw about 1/2 turn out or to suit.
cheers Dave
| Top |
[ 7 posts ] |
Users browsing this forum: No registered users and 10 guests |
