| ducatipaso.org http://www.ducatipaso.org/forum/ |
| 906 repairs / adjustments http://www.ducatipaso.org/forum/viewtopic.php?f=2&t=1800 |
| Author: | enzo906 [ Tue Jun 12, 2007 3:23 am ] |
| Post subject: | 906 repairs / adjustments |
| Author: | persempre907 [ Sun Jun 17, 2007 6:23 am ] |
| Post subject: | |
Hi Enzo, the water leak from the pump is a frequent issue. It's quite easy fix it: you need only replace the ring on the shaft. The water pump is the same of the later Ducati, so you wouldn't have any problem to find it. Unfortunately, I haven't any experience with the Dellorto carbs. I cant' help you. Ciao |
| Author: | marshman [ Sat Jun 23, 2007 7:59 am ] |
| Post subject: | |
Howzit Welcome to 906 land,once your on top of it dude" she'll be right !bro".The faults are plentiful but are all easily overcome.Most parts [crank ]are shared with 907,851,916,ST2 etc [eg all water cooled models] Couple questions : How you testing for manifold air leaks ??have you set vacuum for ignition unit[assuming you got OEM Magnetti-marreli digiplex unit] Ducs are very easy to work on if you have a good mechanical mind .Common size hex heads all over .but beware the Italians like 15mm as a bolthead size. Cheers Andrew |
| Author: | jomo [ Wed Aug 01, 2007 11:33 pm ] |
| Post subject: | |
