| ducatipaso.org http://www.ducatipaso.org/forum/ |
| Crankcase breather plug http://www.ducatipaso.org/forum/viewtopic.php?f=2&t=1661 |
| Author: | MetalHurlant [ Thu Mar 29, 2007 11:51 pm ] |
| Post subject: | Crankcase breather plug |
Hi Folks, What would be causing oil to be leaking out from the crankcase breather plug on my 906? I have replaced the plug with a new one and the hose and clamps as well, but it still leaks. It seems to get worse when I have a cylinder drop out, which is happening very frequently now, but I'm worried that compression is getting through the rings into the crankcase - can anyone help? Ian |
| Author: | Finnpaso [ Fri Mar 30, 2007 2:28 pm ] |
| Post subject: | |
Better, that You check compressing pressures and also that flow passing piston rings..... I dont know english word, but in Finland that is "ohivirtaus mittaus" :laugh: |
| Author: | persempre907 [ Fri Mar 30, 2007 8:15 pm ] |
| Post subject: | |
| Author: | Fraser [ Fri Mar 30, 2007 11:08 pm ] |
| Post subject: | |
| Author: | MetalHurlant [ Sat Mar 31, 2007 1:36 am ] |
| Post subject: | |
