| ducatipaso.org http://www.ducatipaso.org/forum/ |
| Fitting 900SS headers to a 750 Sport http://www.ducatipaso.org/forum/viewtopic.php?f=13&t=3232 |
| Author: | jsey [ Fri Apr 17, 2009 4:35 pm ] |
| Post subject: | Fitting 900SS headers to a 750 Sport |
Hi all I purchased a nice set of 1995 900 SS headers the other day after having found out they will fit my 1990 750 Sport. The headers came with the retainers and I noticed that the retainer are a slide fit over the flanged end of the header. Am I missing some sort of shim that holds the header tight to the head, if so does anybody know where i can buy them? Thanks. |
| Author: | ducinthebay [ Fri Apr 17, 2009 5:22 pm ] |
| Post subject: | Re: Fitting 900SS headers to a 750 Sport |
Yeah, there are two steel half shell type of things that you need for each pipe. this was a change in later models and allowed things to move a bit more without creating exhaust leaks. You need a total of 4 of them. They fit around the pipe and touch off on the flange on the pipe and the retaining collar. Cheers, |
| Author: | Tamburinifan [ Fri Apr 17, 2009 11:16 pm ] |
And closest to heads, there is a copper gasket. |
| Author: | jsey [ Sat Apr 18, 2009 11:16 am ] |
Thanks guys. Any ideas as to where they can be found? |
