| ducatipaso.org http://www.ducatipaso.org/forum/ |
| Cambelts - before changing http://www.ducatipaso.org/forum/viewtopic.php?f=13&t=2657 |
| Author: | anton88 [ Sun Aug 10, 2008 9:52 pm ] |
| Post subject: | Cambelts - before changing |
Right, first job now the bikes home is to change cambelts. Ive some on order, waiting for the postman. Heres some pics of the condition when i took the covers off : The centre / crank pulleys: The horizontal belt: The vertical belt: The bike had been standing for quite some time before i took it home, and no idea when belts last changed, but there didnt sem to be any major concerns or damage to them. However, there is a load of crap around the vertical cam pulley - not sure if its old rubber or oiley dirt (any way it will all be cleaned away nefore the new belts go on) : |
| Author: | Finnpaso [ Mon Aug 11, 2008 3:29 pm ] |
| Post subject: | Re: Cambelts - before changing |
I am QUESSING now, that someone have tighten too much those belt cover screws, then that rubber start to turn and it can hit to belt and grinding start. I noticed thiskind one time, when i turned those screws too much and then that rubber part started to turn and belt touched that rubber and started to make some noise.... I opened immdiatelly covers and find small part of rubber gone away already... As I say, this is quessing..... |
| Author: | Desmo_Demon [ Tue Aug 12, 2008 12:32 pm ] |
| Author: | Finnpaso [ Wed Aug 13, 2008 11:53 am ] |
It can be also so, as U say.... Also all pulley(and "lead rollers" bearings) must be roll easily without too much friction. I have seen many Ducatis, what have lost those bearings and then its again bad thing.....and very harmfull to belts.....
| Author: | ducapaso [ Wed Aug 13, 2008 4:26 pm ] |
This might also be the right time to make an accurate ceck to the bearings and wonder if it's bettere to upgrade to roller/bearing alike newer desmodue |
| Author: | 20YearOwner [ Mon Aug 18, 2008 12:56 am ] |
Changing belts, its really and easy project when you have the manual. Also go to Ducatitech.com and see the video. |
| Author: | jcslocum [ Mon Aug 18, 2008 1:32 pm ] |
or: http://www.ducatisuite.com/valves.html |
| Author: | anton88 [ Mon Aug 18, 2008 3:30 pm ] |
Thanks for the tips Guys. Upon closer inspection, its definitley a mixture of dirt and rubber, but i think its accumulated over quite some time. I havent fitted the new belts yet, as the engine is coming out for a thorough clean degrease and bit of paint before checking and replacing any parts. I can see that the vertical belt has been rubbing on something (not by much), but cant see where yet - should be able to see where once its all clean. |
| Author: | Mc tool [ Thu Oct 16, 2008 11:29 pm ] |
wouldn't hurt to change the oil seals behind the cam pullies , probly should do the ones in the clutch too |
