ducatipaso.org
http://www.ducatipaso.org/forum/
Let there be light!
http://www.ducatipaso.org/forum/viewtopic.php?f=1&t=3552
Author:  PasoRoo [ Tue Aug 11, 2009 12:18 pm ]
Post subject:  Let there be light!
Hi All,
Last weekend I installed a headlight relay kit from Eastern Beaver and it sure makes a difference! The kit arrived quickly and the package contained all the necessary parts. They even threw in an extra fuse and a bunch of zip-ties. It plugs into the standard wiring loom and was dead easy to install.
In the process I figured out how to remove all the bodywork because to get at the headlight I pretty much had to take of all the plastic. I turned on the headlight before installing the kit and after and the difference is huge! The 'after' check had me seeing red balls for the next hour...
All I need now is new gaskets for the oil drain plug and the oil filter, change the oil and put the bodywork back on. As it turns out it is next to impossible in Canberra to get parts for a Duc that hasn't just rolled off the showroom floor, so I'll have to find someone that can supply parts for the Paso.
Mike
Link to the relay kit: http://easternbeaver.com/Main/Products/ ... _kits.html
Page 1 of 1 All times are UTC
http://www.phpbb.com/
