ducatipaso.org
http://www.ducatipaso.org/forum/
Source for Black Plastic washers...
http://www.ducatipaso.org/forum/viewtopic.php?f=1&t=3165
Author:  renzo750 [ Tue Mar 24, 2009 2:46 am ]
Post subject:  Source for Black Plastic washers...
Hello All,
Been a long time..guess I finally have something to add.
I discovered Buell Part # BA0409.6BL will get you a nice black plastic washer to use on your Paso body work.
UPDATE:
I must apologize for my "quick" post; in side by side measurements the Buell washer is a bit different. The washer, from a Ulysses lower front fender connection:
Buell is .8mm thick, 14.25mm OD 6.66mm ID
OEM Paso is 1mm thick, 15mm OD and 7.60mmID
The hole on the Buell is a tad small to fit the Paso OEM screw; however…with a careful hand it could be made to work.
Jim...Centerville, Mn Orignal owner '87 Paso 750 #1164.
Author:  silverfox [ Tue Mar 24, 2009 9:09 pm ]
Post subject:  Re: Source for Black Plastic washers...
Nice one, thanks for the part number but the guy is bound to ask "what's it from?"
Is it a panel screw washer on the Buell?
Tony
Author:  persempre907 [ Wed Mar 25, 2009 9:46 am ]
Have those washers exactly the same measures of the stock ones?
I can't stand the transparent ones sold at the Ducati dealers.
Author:  higgy [ Wed Mar 25, 2009 11:26 am ]
Bevel Heaven 10 pack 8 us
Bodywork Rubber Washer 10 Pack
KL-313197
I am sure there are many others not to mention your local industrial fastener supply house. These are very common parts easy to find
Page 1 of 1 All times are UTC
http://www.phpbb.com/
