It is currently Wed Oct 01, 2025 7:14 pm
 Post subject: Source for Black Plastic washers...
PostPosted: Tue Mar 24, 2009 2:46 am
Hello All,
Been a long time..guess I finally have something to add.
I discovered Buell Part # BA0409.6BL will get you a nice black plastic washer to use on your Paso body work.
UPDATE:
I must apologize for my "quick" post; in side by side measurements the Buell washer is a bit different. The washer, from a Ulysses lower front fender connection:
Buell is .8mm thick, 14.25mm OD 6.66mm ID
OEM Paso is 1mm thick, 15mm OD and 7.60mmID
The hole on the Buell is a tad small to fit the Paso OEM screw; however…with a careful hand it could be made to work.
Jim...Centerville, Mn Orignal owner '87 Paso 750 #1164.
 Post subject: Re: Source for Black Plastic washers...
PostPosted: Tue Mar 24, 2009 9:09 pm
Nice one, thanks for the part number but the guy is bound to ask "what's it from?"
Is it a panel screw washer on the Buell?
Tony
PostPosted: Wed Mar 25, 2009 9:46 am
Have those washers exactly the same measures of the stock ones?
I can't stand the transparent ones sold at the Ducati dealers.
PostPosted: Wed Mar 25, 2009 11:26 am
Bevel Heaven 10 pack 8 us
Bodywork Rubber Washer 10 Pack
KL-313197
I am sure there are many others not to mention your local industrial fastener supply house. These are very common parts easy to find
Users browsing this forum: No registered users and 59 guests
