It is currently Thu Oct 02, 2025 10:42 am
 Post subject: Open Silentium Exhaust
PostPosted: Fri Mar 27, 2009 12:48 pm
Hello All,
Via Windtrading Srl in Italy I'm trying to convince Silmoto to manufacture another set of the following open exhausts from the so-called uprating kit:
- 40mm horizontal exhaust pipe 0370.84.023
- 40mm vertical exhaust pipe 0370.84.033
- open right hand exhaust 573.1.003.1A
- open left hand exhaust 574.1.003.1A
Anybody else interested in a set?
Mark
 Post subject: Re: Open Silentium Exhaust
PostPosted: Fri Mar 27, 2009 1:57 pm
Hi Mark,
do you happen to know the difference between the 0370.84.020 and the 0370.84.023 ?
Guess you do if you want to have it made. I`m wondering as the vertical tube 0370.84.033 is used on both headers so they do have the same diameter. Where`s the difference ?!
Gerhard
PostPosted: Wed Apr 01, 2009 7:06 am
Hi Gerhard,
I was under the impression that the standard headers have a 36mm diameter. Great news if I only need the open exhausts!
Mark
PostPosted: Wed Apr 01, 2009 7:52 am
check this thread
viewtopic.php?f=1&t=3094
Users browsing this forum: No registered users and 74 guests
