It is currently Wed Oct 01, 2025 12:49 pm
 Post subject: Acid batery and swingarm
PostPosted: Wed Jul 23, 2008 8:26 am
My bike is all stock, except exhaust "silmotor" carbon....
I have a problem with some spots of acid batery that leaked in to the swingarm!!! :(
Does anyone know how to remove this spots??? and how to restore the original finish of the alloy swingarm....
 Post subject: Re: Acid batery and swingarm
PostPosted: Wed Jul 23, 2008 10:17 am
Actually there`s no way to remove the spots as the acid corroded itself through the anodized layer.
Restoring it to old condition is not easy. The anodized layer would need to be removed and that is usually done via sandbead blasting or etchant. Both ways I would not recommend as they are aggressive and can weaken the material. Glasbead blasting is probably the best way and then anodize again.
I guess I personally would look for a semi gloss clear coat, clean the spots and just paint them to prevent any oxidation.
PostPosted: Wed Jul 23, 2008 8:15 pm
If you take it to a shop that does anodize, they can strip it, and re-anodize the part. It will probably be more dull looking than it does now since the etchant to take off the anodize will also etch the aluminum underneath it.
If you want to polish it, then you can remove the anodize with off the shelf oven cleaner. Its pretty caustic, so wear glasses, gloves, and a lab apron. as with all chemical reactions, heat helps. The part will be a bit splotchy in appearance, but polishing it will take care of that.
Thats a lot of work for some little spots, but it might be worth it to you. You will have to get all new swingarm bearings while you are at it.
Users browsing this forum: No registered users and 78 guests
