ducatipaso.org • View topic - Coil Failure?
It is currently Fri Dec 19, 2025 12:54 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sun Feb 25, 2007 11:45 pm
Jon:
Hell no! [laughing]
I am going to check the resistance and the idle speed voltage using a different, more accurate multitester. If my results are the same or still over spec, I am going to get new coils.
I am going to apply your relay mod in any case.
Hopefully I can eliminate the electricals as being the cause, and go back to the carb.
Brett
PostPosted: Mon Feb 26, 2007 1:15 am
A more accurtate meter will only make the voltage worse!
Fixing the electrics will help narrow the problems.
PostPosted: Tue Feb 27, 2007 6:09 am
